POSIX API ?
Pierre FICHEUX pierre.ficheux at smile.fr
Sun Oct 30 19:11:56 UTC 2016
Hi,
See answers below.
Pierre FICHEUX -/- Smile/OWI, France -\- pierre.ficheux at smile.fr
                                          http://ingenierie.openwide.fr
                                          http://www.linuxembedded.fr
I would love to change the world, but they won't give me the source
code
Le 2016-10-30 16:55, Oyake, Amalaye (398F) a écrit :
> Hello Pierre,
> It may be helpful (for the maintainers) to state:
> 1. Your build commands.
Same as before:
$ ../rtems_git/configure --target=i386-rtems4.12 --disable-cxx
--disable-networking --enable-rtemsbsp=pc386 --prefix=<install-dir>
> 2. Your HOST and BSP.
Host is PC/x86_64 (is it what you cal HOST?), target is pc386 (same
test and result with raspberrypi as target)
> 3. What platform you are building on (including the version of the
> OS).
Ubuntu 14.04 LTS
> 4. What platform you are running it on.
QEMU (for pci386) or Raspberry Pi B+
> 5. Whether you are using a simulator or a real system.
See previous answer.
> 6. A copy of the error message.
No error message but the timer (1 sec period) doesn't work...program
displays the following lines without any (1 sec) pause.
Got signal 14
Got signal 14
Got signal 14
Got signal 14
Got signal 14
Got signal 14
Got signal 14
Got signal 14
Got signal 14
It worked fine with RTEMS Version 4.10.99.0.
Of course example-v2/led/timer example (classic API) works fine.
regards
> Regards,
> * Amalaye Oyake                                       *
> * Instrument Product Software Development Group  */\  *
> * Jet Propulsion Laboratory, Pasadena            *||  *
> * CA 91109                                       /||\ *
> On 10/30/16, 7:13 AM, "users on behalf of Pierre FICHEUX"
> <users-bounces at rtems.org on behalf of pierre.ficheux at smile.fr> wrote:
>     Hi all,
>     Just back to RTEMS after a long time. I've build the last version
> (Git)
>     with last compiler (4.12) and looks like a simple POSIX timer
> doen't
>     work anymore... It should display "Signal 14" every second but
> period is
>     veryyyy short...and display very fast :(
>     Any idea? any change in the way to use POSIX with RTEMS?
>     See my program attached (it works fine with Linux).
>     I have tested with Raspberry Pi and QEMU/i386.
>     thx by advance
> source
>     code
