Debugging problem with insight debugger
    Gene Smith
    gds at chartertn.net
    Sat Sep  3 04:57:38 UTC 2016
I have been trying to use the insight debugger on one of the example
programs, examples-v2/led/timer. This is using a stm32f4-discovery board
with the st-util gdbserver from here: https://github.com/texane/stlink.
Basically it works OK but I see a weird problem when debugging with
insight from this project: https://github.com/monnerat/insight/
The details are described here:
https://github.com/monnerat/insight/issues/9.
Basically it seems to be a name clash between the rtems application file
called init.c and a newlib file also called init.c (at least that's my
theory).
I'm not an expert on gdb or insight so if anyhow has ideas as to what is
wrong I would appreciate any information.
Thanks,
-gene
