Simple question about RTL
xuelin.tian at qkmtech.com
Mon Sep 5 13:19:54 UTC 2016
Hello Pavel,
The RTEMS version is 4.11-release.
Today, I download the latest 4.11-release with "fix cache corruption bugs" patch, and build it. I use the new tool-chain and bsp to build my application and the bug remains.
And I check my appdl-symbol-table.o via arm-rtems4.11-nm, no "hello_world" (which is the function I want to jump to) found. Is it correct? I follow your instructions to get .prelink, to get symbol table, and to get the final image. Do you have any hints on this? Thank you.
Best wishes,
Tim Tian
Date: 2016-09-04 21:10
To: xuelin.tian at qkmtech.com
CC: users at rtems.org; Chris Johns
Subject: Re: Simple question about RTL
Hello Tim Tian,
On Sunday 04 of September 2016 14:52:44 xuelin.tian at qkmtech.com wrote:
> This problem drives me crazy.
> I can use dlopen to load my object file, this part works fine. When I loaded the object file, it showed something like:
> > handle: 0x2a9bb0 loaded
> And then I could get the address of this handle via dlsym,
> > call = dlsym(handle, "hello_world");
> > if (call == NULL) {
> > printf("dlsym failed: symbol hello_world not found\n");
> > return 1;
> > printf("address: %x\n", call);
> it said like:
> > address: 2aa3a1
> But, when I continued to jump to the entry point of call, the system
> crashed.
what is the RTEMS sources version?
I have tested RTL on Zynq about last week and it worked correctly.
I use actual RTEMS master git sources.
If you use RTEMS build before next patch then it is highly probable
that you experience failures on stargets with cache enabled.
libdl/rtl-obj.c: synchronize cache after code relocation.
Pavel Pisa<pisa at cmp.felk.cvut.cz>
7/21/16 2:35 AM
There is even another patch which synchronizes and cleans cache during startup
arm/xilinx_zynq: ensure that cache is cleaned and MMU disabled when initialization starts.
Chris Johns<chrisj at rtems.org>
8/31/16 4:49 PM
It should not be crucial for UP (non SMP) use. But it would worth
to retest your actual RTEMS master version.
If you are working with stable RTEMS 4.11 pre-release branch
then problems are not fixed there.
I think that it would worth to consider whole cache related
issues update for 4.11 branch as well.
Best wishes,
Pavel
URL: <http://lists.rtems.org/pipermail/users/attachments/20160905/9b3fe987/attachment.html>
