Network problem for altcycv_devkit
Tue Sep 6 13:12:23 UTC 2016
I don't recommend to use the RTEMS 4.11 network interface driver
included in the RTEMS main repository. It wasn't removed by accident
from the repository.
On 06/09/16 15:10, Jianxun Yan wrote:
> Hi Sebastian,
> Thank you for answering the email.
> Adit helped me to fixed the problem. Instead of running rtems4.12, I
> have to run rtems4.11. Seems rtems4.12 bsp.h file doesn't have the
> macro of RTEMS_BSP_NETWORK_DRIVER_ATTACH.
> Thanks,
> Jay
> On 09/06/2016 04:42 AM, Sebastian Huber wrote:
>> On 25/08/16 16:32, Jianxun Yan wrote:
>>> Hi Sebastian,
>>> How should I configure the network? Should I use both struct
>>> rtems_bsdnet_config and rtems_bsdnet_ifconfig?
>> No, the configuration of the new network stack works completely
>> different.
>>> Do you have any example for altcycv_devkit network?
>> Yes, just build the new network stack for your BSP and run the ftpd01
>> test program.
>>> Thank you very much for your help.
>>> Jay Yan
>>> On 08/25/2016 10:18 AM, Sebastian Huber wrote:
>>>> The network interface, USB and MMC drivers are part of the libbsd
>>>> for this BSP.
>>>> ----- Am 25. Aug 2016 um 15:12 schrieb Jianxun Yan yanjx at jlab.org:
>>>>> Hi,
>>>>> Since nobody answered my question, I have to post it again. Anyone
>>>>> can
>>>>> help me?
>>>>> Thanks,
>>>>> Jay Yan
>>>>> On 08/23/2016 11:43 AM, Jianxun Yan wrote:
>>>>>> Hi,
>>>>>> Have anyone ever ran the network application for the Altera
>>>>>> Cyclone V
>>>>>> SoC board (BSP altcycv_devkit)? When I tried to configure the
>>>>>> network
>>>>>> interface, I couldn't find the attach network driver. What attach
>>>>>> driver will be for RTEMS_BSP_NETWORK_DRIVER_ATTACH on the
>>>>>> Thanks,
>>>>>> Jay Yan
>>>>>> _______________________________________________
>>>>>> users mailing list
>>>>>> users at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>> users mailing list
>>>>> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
