Network problem for altcycv_devkit
Jianxun Yan yanjx at jlab.org
Tue Sep 6 13:16:00 UTC 2016
Hi Sebastian,
I don't understand. Should I use RTEMS 4.11 or not?
Thanks,
Jay
On 09/06/2016 09:12 AM, Sebastian Huber wrote:
> I don't recommend to use the RTEMS 4.11 network interface driver
> included in the RTEMS main repository. It wasn't removed by accident
> from the repository.
> On 06/09/16 15:10, Jianxun Yan wrote:
>> Hi Sebastian,
>> Thank you for answering the email.
>> Adit helped me to fixed the problem. Instead of running rtems4.12, I
>> have to run rtems4.11. Seems rtems4.12 bsp.h file doesn't have the
>> macro of RTEMS_BSP_NETWORK_DRIVER_ATTACH.
>> Thanks,
>> Jay
>> On 09/06/2016 04:42 AM, Sebastian Huber wrote:
>>> On 25/08/16 16:32, Jianxun Yan wrote:
>>>> Hi Sebastian,
>>>> How should I configure the network? Should I use both struct
>>>> rtems_bsdnet_config and rtems_bsdnet_ifconfig?
>>> No, the configuration of the new network stack works completely
>>> different.
>>>> Do you have any example for altcycv_devkit network?
>>> Yes, just build the new network stack for your BSP and run the
>>> ftpd01 test program.
>>>> Thank you very much for your help.
>>>> Jay Yan
>>>> On 08/25/2016 10:18 AM, Sebastian Huber wrote:
>>>>> The network interface, USB and MMC drivers are part of the libbsd
>>>>> for this BSP.
>>>>> ----- Am 25. Aug 2016 um 15:12 schrieb Jianxun Yan yanjx at jlab.org:
>>>>>> Hi,
>>>>>> Since nobody answered my question, I have to post it again.
>>>>>> Anyone can
>>>>>> help me?
>>>>>> Thanks,
>>>>>> Jay Yan
>>>>>> On 08/23/2016 11:43 AM, Jianxun Yan wrote:
>>>>>>> Hi,
>>>>>>> Have anyone ever ran the network application for the Altera
>>>>>>> Cyclone V
>>>>>>> SoC board (BSP altcycv_devkit)? When I tried to configure the
>>>>>>> network
>>>>>>> interface, I couldn't find the attach network driver. What attach
>>>>>>> driver will be for RTEMS_BSP_NETWORK_DRIVER_ATTACH on the
>>>>>>> Thanks,
>>>>>>> Jay Yan
>>>>>>> _______________________________________________
>>>>>>> users mailing list
>>>>>>> users at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>>> users mailing list
>>>>>> users at rtems.org
