Network problem for altcycv_devkit
Tue Sep 6 13:18:56 UTC 2016
I would use RTEMS 4.12 (the latest Git master of RTEMS) on the Altera
Cyclone V and the libbsd network interface driver.
If you want to use RTEMS 4.11, then I would still use the libbsd network
interface driver.
On 06/09/16 15:16, Jianxun Yan wrote:
> Hi Sebastian,
> I don't understand. Should I use RTEMS 4.11 or not?
> Thanks,
> Jay
> On 09/06/2016 09:12 AM, Sebastian Huber wrote:
>> I don't recommend to use the RTEMS 4.11 network interface driver
>> included in the RTEMS main repository. It wasn't removed by accident
>> from the repository.
>> On 06/09/16 15:10, Jianxun Yan wrote:
>>> Hi Sebastian,
>>> Thank you for answering the email.
>>> Adit helped me to fixed the problem. Instead of running rtems4.12, I
>>> have to run rtems4.11. Seems rtems4.12 bsp.h file doesn't have the
>>> macro of RTEMS_BSP_NETWORK_DRIVER_ATTACH.
>>> Thanks,
>>> Jay
>>> On 09/06/2016 04:42 AM, Sebastian Huber wrote:
>>>> On 25/08/16 16:32, Jianxun Yan wrote:
>>>>> Hi Sebastian,
>>>>> How should I configure the network? Should I use both struct
>>>>> rtems_bsdnet_config and rtems_bsdnet_ifconfig?
>>>> No, the configuration of the new network stack works completely
>>>> different.
>>>>> Do you have any example for altcycv_devkit network?
>>>> Yes, just build the new network stack for your BSP and run the
>>>> ftpd01 test program.
>>>>> Thank you very much for your help.
>>>>> Jay Yan
>>>>> On 08/25/2016 10:18 AM, Sebastian Huber wrote:
>>>>>> The network interface, USB and MMC drivers are part of the libbsd
>>>>>> for this BSP.
>>>>>> ----- Am 25. Aug 2016 um 15:12 schrieb Jianxun Yan yanjx at jlab.org:
>>>>>>> Hi,
>>>>>>> Since nobody answered my question, I have to post it again.
>>>>>>> Anyone can
>>>>>>> help me?
>>>>>>> Thanks,
>>>>>>> Jay Yan
>>>>>>> On 08/23/2016 11:43 AM, Jianxun Yan wrote:
>>>>>>>> Hi,
>>>>>>>> Have anyone ever ran the network application for the Altera
>>>>>>>> Cyclone V
>>>>>>>> SoC board (BSP altcycv_devkit)? When I tried to configure the
>>>>>>>> network
>>>>>>>> interface, I couldn't find the attach network driver. What attach
>>>>>>>> driver will be for RTEMS_BSP_NETWORK_DRIVER_ATTACH on the
>>>>>>>> Thanks,
>>>>>>>> Jay Yan
>>>>>>>> _______________________________________________
>>>>>>>> users mailing list
>>>>>>>> users at rtems.org
>>>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>>>> users mailing list
>>>>>>> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
