Network problem for altcycv_devkit
Jianxun Yan yanjx at jlab.org
Tue Sep 6 13:31:54 UTC 2016
I really got confused. On RTEMS 4.12, where can I find the macro
RTEMS_BSP_NETWORK_DRIVER_ATTACH? or do I need it? Where I can find the
the ftpd01 test program than you mentioned?
Thanks,
Jay
On 09/06/2016 09:18 AM, Sebastian Huber wrote:
> I would use RTEMS 4.12 (the latest Git master of RTEMS) on the Altera
> Cyclone V and the libbsd network interface driver.
> If you want to use RTEMS 4.11, then I would still use the libbsd
> On 06/09/16 15:16, Jianxun Yan wrote:
>> Hi Sebastian,
>> I don't understand. Should I use RTEMS 4.11 or not?
>> Thanks,
>> Jay
>> On 09/06/2016 09:12 AM, Sebastian Huber wrote:
>>> I don't recommend to use the RTEMS 4.11 network interface driver
>>> included in the RTEMS main repository. It wasn't removed by accident
>>> from the repository.
>>> On 06/09/16 15:10, Jianxun Yan wrote:
>>>> Hi Sebastian,
>>>> Thank you for answering the email.
>>>> Adit helped me to fixed the problem. Instead of running rtems4.12,
>>>> I have to run rtems4.11. Seems rtems4.12 bsp.h file doesn't have
>>>> the macro of RTEMS_BSP_NETWORK_DRIVER_ATTACH.
>>>> Thanks,
>>>> Jay
>>>> On 09/06/2016 04:42 AM, Sebastian Huber wrote:
>>>>> On 25/08/16 16:32, Jianxun Yan wrote:
>>>>>> Hi Sebastian,
>>>>>> How should I configure the network? Should I use both struct
>>>>>> rtems_bsdnet_config and rtems_bsdnet_ifconfig?
>>>>> No, the configuration of the new network stack works completely
>>>>> different.
>>>>>> Do you have any example for altcycv_devkit network?
>>>>> Yes, just build the new network stack for your BSP and run the
>>>>> ftpd01 test program.
>>>>>> Thank you very much for your help.
>>>>>> Jay Yan
>>>>>> On 08/25/2016 10:18 AM, Sebastian Huber wrote:
>>>>>>> The network interface, USB and MMC drivers are part of the
>>>>>>> libbsd for this BSP.
>>>>>>> ----- Am 25. Aug 2016 um 15:12 schrieb Jianxun Yan yanjx at jlab.org:
>>>>>>>> Hi,
>>>>>>>> Since nobody answered my question, I have to post it again.
>>>>>>>> Anyone can
>>>>>>>> help me?
>>>>>>>> Thanks,
>>>>>>>> Jay Yan
>>>>>>>> On 08/23/2016 11:43 AM, Jianxun Yan wrote:
>>>>>>>>> Hi,
>>>>>>>>> Have anyone ever ran the network application for the Altera
>>>>>>>>> Cyclone V
>>>>>>>>> SoC board (BSP altcycv_devkit)? When I tried to configure the
>>>>>>>>> network
>>>>>>>>> interface, I couldn't find the attach network driver. What attach
>>>>>>>>> driver will be for RTEMS_BSP_NETWORK_DRIVER_ATTACH on the
>>>>>>>>> Thanks,
>>>>>>>>> Jay Yan
>>>>>>>>> _______________________________________________
>>>>>>>>> users mailing list
>>>>>>>>> users at rtems.org
>>>>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>>>>> users mailing list
>>>>>>>> users at rtems.org
