rtems on beaglebone black
MH Najmi
mh_najmi at yahoo.com
Tue Sep 13 10:55:05 UTC 2016
hi...before all things i excuse for my bad english...
i make your source-builder for bbb by ""../source-builder/sb-set-builder --log=beagle.txt --prefix=$HOME/development/rtems/4.12 devel/beagle.bset"" more than 20 times but when it builds "error: building arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-i686-linux-gnu-1
"or qemu after building about 5 - 6 GB failed with this message:
Build FAILED
See error report: rsb-report-arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-i686-linux-gnu-1.txt
Build Set: Time 0:02:18.668988
Build FAILED
can you help me ? i think if i change the python code of building thr source builder in such way that it doesn't repeat building those files that build before it will be correct....because each time it build different size ..the most size that i could build was 7.5 GB.but for qemu it was failed
I got help from "http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html"
URL: <http://lists.rtems.org/pipermail/users/attachments/20160913/9920c5cc/attachment.html>
