How to make use of B1553BRM
Charles INGELS charles.ingels at syderal.ch
Fri Sep 30 13:48:23 UTC 2016
Dear all,
I am trying to use the B1553BRM driver on a LEON3 dual core based board
but I am a little bit confused on the way to open and to use the device.
Coming from the Linux world, I see that it is possible to do the following :
fd = open("/dev/brm0", O_RDWR);
(POSIX interface)
However, I do not have a filesystem because I have no need of it (except
maybe to have the descriptor node available ?).
Such call returns an errno = 2, which means ENOENT.
I try to switch to the RTEMS API by using the rtems_io_open(...)
function and the returned status is 25 "Internal error". This is
understandable since I do neither know the major number nor the minor
number for the BRM1553 configured as an RT device (I put 0 for both the
major and minor parameters).
So my questions are :
1 - is the RTEMS API usable to open the B1553BRM driver instead of the
POSIX API ?
2 - where can I find the major and minor numbers for the B1553BRM device ?
3 - where can I find some examples on how to make use of such drivers ?
For information, I want to use the B1553BRM as an RT device only.
Thanks you a lot in advance for your answers !
Charles
*Charles INGELS*
Embedded software expert
Phone /+41 (0)32 338 99 10/
iNum /+883 5100 0902 7759/
*SYDERAL SA*
Neuenburgstrasse 7
CH-3238 Gals (Suisse)
Desk /+41 (0)32 338 98 00/
Fax /+41 (0)32 338 99 34/
Web site http://www.syderal.ch
URL: <http://lists.rtems.org/pipermail/users/attachments/20160930/dc924009/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160930/dc924009/attachment-0001.png>
