rtems-addon-packages removed?
Fri Sep 30 17:04:55 UTC 2016
On Fri, Sep 30, 2016 at 11:57 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Sep 30, 2016 10:49 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
>> Looks like it was renamed: https://git.rtems.org/libbsdport/
> That's the port of newer drivers to the old tcpip stack.
>> Also, https://devel.rtems.org/ticket/2469 indicates some progress was made
>> to convert it to RSB configurations/recipes, after which the git repo would
>> become obsolete.
> That's the reason. You can build them all with the rsb. The graphics toolkit
> has only a couple of packages left and it follows the same fate.
Where are the recipes in the RSB? A quick look was not obvious.
