Network problem for altcycv_devkit
    Sebastian Huber
    Tue Sep  6 13:37:56 UTC 2016
On 06/09/16 15:31, Jianxun Yan wrote:
> I really got confused. On RTEMS 4.12, where can I find the macro
> RTEMS_BSP_NETWORK_DRIVER_ATTACH? or do I need it? Where I can find the
> the ftpd01 test program than you mentioned?
As I said before the network interface, USB and MMC drivers are part of
the libbsd for this BSP. Its configuration is completely different.
https://git.rtems.org/rtems-libbsd/tree/README.waf
https://git.rtems.org/rtems-libbsd/tree/libbsd.txt
> Thanks,
> Jay
> On 09/06/2016 09:18 AM, Sebastian Huber wrote:
>> I would use RTEMS 4.12 (the latest Git master of RTEMS) on the Altera
>> Cyclone V and the libbsd network interface driver.
>> If you want to use RTEMS 4.11, then I would still use the libbsd
>> On 06/09/16 15:16, Jianxun Yan wrote:
>>> Hi Sebastian,
>>> I don't understand. Should I use RTEMS 4.11 or not?
>>> Thanks,
>>> Jay
>>> On 09/06/2016 09:12 AM, Sebastian Huber wrote:
>>>> I don't recommend to use the RTEMS 4.11 network interface driver
>>>> included in the RTEMS main repository. It wasn't removed by
>>>> accident from the repository.
>>>> On 06/09/16 15:10, Jianxun Yan wrote:
>>>>> Hi Sebastian,
>>>>> Thank you for answering the email.
>>>>> Adit helped me to fixed the problem. Instead of running rtems4.12,
>>>>> I have to run rtems4.11. Seems rtems4.12 bsp.h file doesn't have
>>>>> the macro of RTEMS_BSP_NETWORK_DRIVER_ATTACH.
>>>>> Thanks,
>>>>> Jay
>>>>> On 09/06/2016 04:42 AM, Sebastian Huber wrote:
>>>>>> On 25/08/16 16:32, Jianxun Yan wrote:
>>>>>>> Hi Sebastian,
>>>>>>> How should I configure the network? Should I use both struct
>>>>>>> rtems_bsdnet_config and rtems_bsdnet_ifconfig?
>>>>>> No, the configuration of the new network stack works completely
>>>>>> different.
>>>>>>> Do you have any example for altcycv_devkit network?
>>>>>> Yes, just build the new network stack for your BSP and run the
>>>>>> ftpd01 test program.
>>>>>>> Thank you very much for your help.
>>>>>>> Jay Yan
>>>>>>> On 08/25/2016 10:18 AM, Sebastian Huber wrote:
>>>>>>>> The network interface, USB and MMC drivers are part of the
>>>>>>>> ----- Am 25. Aug 2016 um 15:12 schrieb Jianxun Yan yanjx at jlab.org:
>>>>>>>>> Hi,
>>>>>>>>> Since nobody answered my question, I have to post it again.
>>>>>>>>> Anyone can
>>>>>>>>> help me?
>>>>>>>>> Thanks,
>>>>>>>>> Jay Yan
>>>>>>>>> On 08/23/2016 11:43 AM, Jianxun Yan wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> Have anyone ever ran the network application for the Altera
>>>>>>>>>> Cyclone V
>>>>>>>>>> SoC board (BSP altcycv_devkit)? When I tried to configure the
>>>>>>>>>> network
>>>>>>>>>> interface, I couldn't find the attach network driver. What
>>>>>>>>>> attach
>>>>>>>>>> driver will be for RTEMS_BSP_NETWORK_DRIVER_ATTACH on the
>>>>>>>>>> Thanks,
>>>>>>>>>> Jay Yan
>>>>>>>>>> _______________________________________________
>>>>>>>>>> users mailing list
>>>>>>>>>> users at rtems.org
>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>>>>>> users mailing list
>>>>>>>>> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
