RTEMS 4.11.2-rc3 Release
Thu Apr 6 22:57:47 UTC 2017
On 06/04/2017 21:57, Needell, Jerry wrote:
> looks like there is still an issue  with the use of  “rc”  ;-(  :
> attempted build of sprac-rtems via RSB on Centos7
> download:
> ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz
> -> sources/rtems-tools-4.11.2-rc3.tar.xz
Where did `ftp://ftp.rtems.org/` come from?
What was your command line?
I ask because `ftp://ftp.rtems.org/` is not defined in the RSB source
anywhere:
$ grep -r 'ftp.rtems.org' config/
config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg:%source set gcc
http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-gcc-4.1.tar.bz2
config/tools/rtems-nios2-binutils-2.20-1.cfg:%source set binutils
http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-binutils-2.20.tar.bz2
config/tools/rtems-nios2-gdb-7.0-1.cfg:%source set gdb
http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-gdb-7.0.tar.bz2
and the path used in the release is defined here:
https://git.rtems.org/rtems-release/tree/rtems-release-defaults#n61
I am confused as I tested the RC for just this.
