RTEMS 4.11.2-rc3 Release
Mon Apr 10 06:32:59 UTC 2017
On 10/04/2017 07:02, Joel Sherrill wrote:
> On Apr 9, 2017 3:59 PM, "Needell, Jerry" <Jerry.Needell at unh.edu
> <mailto:Jerry.Needell at unh.edu>> wrote:
>     Joel,
>     Thats just what I am seeing. RC1 worked fine for me as well.
>     When the build gets to rtems-tools  for RC3 it still seems to be
>     looking in :
>     ...releases/4.11/4.11.2-rc3
>     rather than
>     ...releases/4.11/rc/4.11.2-rc3
>     Maybe I’m not imagining this …. ;-)
> No you are not.  :)
> Chris will wake up soon so should answer shortly. I could manually
> download rtems-tools but I don't think that's useful at this point.
> Looks like an rc4 is needed.
The problem is due to these lines:
https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-tools-1.cfg#n28
https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-kernel-4-1.cfg#n67
The `%define without_release_url` was added to the config file because
the tools and kernel source are not located in the `sources` directory,
they are in the release's top level directory.
Removing `%define without_release_url` does not help because we get the
error from the source not being found in `sources` directory.
I think the best solution is to remove the `%define without_release_url`
from the tools and kernel configuration files plus the explicit paths
and update the release scripts to have the tools and kernel source in
the `sources` directory and the release's top level directory. This
means the "release-url" is consistent in all use cases and I can remove
the path hack in the configuration files.
The release's top level directory is just the RTEMS source packages and
I think having a second copy is a minor overhead.
I have reopened #2952.
