Bug fix in 'apbuart_cons.c' file ?
Joel Sherrill
joel at rtems.org
Tue Apr 11 01:29:35 UTC 2017
I'm going to assume that Daniel didn't see this since he didn't comment.
On Apr 10, 2017 2:41 AM, "Charles INGELS" <charles.ingels at syderal.ch> wrote:
Hello,
By using the APB Uart BSP on a SPARC LEON3 target, I think that I have
found something which seems to be incorrect.
In my RTEMS app, I just want to receive data through the UART1. Such data
are then echoed on the same interface.
When I want to open the '/dev/apbuart1' descriptor, I get a 'No such file
or directory' error message. I get the same error message whatever is the
descriptor I try to open ('/dev/apbuart0', ...).
I am using the driver manager and I have defined the
CONFIGURE_DRIVER_AMBAPP_GAISLER_APBUART to have the driver manager create
the device descriptors. However, the descriptors are not created.
I had a look at the content of the following file :
U:\rtems\src2\rtems\c\src\lib\libbsp\sparc\shared\uart\apbuart_cons.c
On line #278, the if statement does not explicitly test the value returned
by the call to function 'drvmgr_get_dev_prefix()'.
Since such function returns 0 in case of success, the content of the if
statement is never executed. Consequently, the variable 'priv->devName' is
never initialized to the right string '/dev/apbuart%d', it is always empty
which seems to explain why the device descriptor is not not created.
I have slightly modified the test with the following code :
if (drvmgr_get_dev_prefix(dev, prefix) != -1)
I explicitly test the returned value against -1 (which is considered as an
error). With that code, the '/dev/apbuartX' device descriptors are
successfully created and communicate with the UART.
So is it a known bug ? Will it be fixed in the next releases ? Is the way I
fixed it correct, or no ?
Such fix works for me but are there some side effects that shall be taken
into account ?
Thanks for your answers,
Regards,
Charles
*Charles INGELS*
Embedded software expert
Phone *+41 (0)32 338 99 10 <+41%2032%20338%2099%2010>*
iNum *+883 5100 0902 7759*
*SYDERAL SA*
Neuenburgstrasse 7
CH-3238 Gals (Suisse)
Desk *+41 (0)32 338 98 00 <+41%2032%20338%2098%2000>*
Fax *+41 (0)32 338 99 34 <+41%2032%20338%2099%2034>*
Web site http://www.syderal.ch
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20170410/cbaf0fd0/attachment-0002.html>
URL: <http://lists.rtems.org/pipermail/users/attachments/20170410/cbaf0fd0/attachment-0003.html>
