RTEMS 4.11.0 build fails on Windows
Linda Huxley lhuxley at shaw.ca
Wed Apr 12 18:35:27 UTC 2017
Thanks Gedare,
I restored Worth's original patch and I made the configuration change
that you suggested.  The patch now appears to be applied correctly, as
shown by the following build log entries:
+ cd gcc-4.9.3
+ chmod -R a+rX,g-w,o-w .
+ cat /C/opt/rtems/4.11.0/rtems/patches/gcc-4.9.3-20170404-1.patch
+ patch -p1
patching file gcc/cp/cfns.gperf
patching file gcc/cp/cfns.h
patching file gcc/cp/except.c
patching file gcc/cp/Make-lang.in
Regards,
Linda
On 2017-04-12 05:37, Gedare Bloom wrote:
> On Tue, Apr 11, 2017 at 10:31 PM, Linda Huxley <lhuxley at shaw.ca> wrote:
>> Thanks Chris,
>>> Is this a log fragment from the RSB?
>> Yes.  There are 4 patches in Worth's patch file.  That is just the piece of
>> the log that shows the problem with the first patch.  (All 4 patches have
>> the same problem.)
>> My command line looks like this:
>> /c/opt/rtems/4.11.0/rtems $ ../source-builder/sb-set-builder
>> --prefix=/opt/rtems/4.11.0 4.11/rtems-sparc --jobs=none
>>> The patches are in `patches` below `rtems` in the RSB. The script
>>> knows this and should handle it.
>> Yes, I have placed the modified patch file here (I have no rsb directory):
>> /c/opt/rtems/4.11.0/rtems/patches $ ls
>> automake-1.12.6-bugzilla.redhat.com-1239379.diff  gcc-4.9.3-20170404-1.patch
> It looks like rtems-source-builder exists in your /c/opt/rtems/4.11.0.
> So this location appears correct from that regards.
> A bit more below:
>> Regards,
>> Linda
>> On 2017-04-11 18:35, Chris Johns wrote:
>>> On 12/04/2017 09:24, Linda Huxley wrote:
>>>>> That is fine. Please ask any questions, I am more than happy to help.
>>>> Thanks Chris,
>>>> Well, I could use some help getting Worth's patch to work.  I have tried
>>>> making the obvious changes to his patch and I'm still getting a
>>>> "can't find a file to patch" error.  For example, after inserting
>>>> "/../gcc-4.9.3" into the difference commands in the patch file, I'm
>>>> seeing the following message from the first difference in the patch:
>>>> + cd newlib-2.2.0.20150423
>>>> + patch -p1
>>>> can't find file to patch at input line 4
>>>> Perhaps you used the wrong -p or --strip option?
>>>> The text leading up to this was:
>>>> |diff -Naur gcc-4.9.3-orig/../gcc-4.9.3/gcc/cp/cfns.gperf
>>>> gcc-4.9.3-fixed/../gcc-4.9.3/gcc/cp/cfns.gperf
>>>> |--- gcc-4.9.3-orig/../gcc-4.9.3/gcc/cp/cfns.gperf    2014-01-02
>>>> 17:23:26.000000000 -0500
>>>> |+++ gcc-4.9.3-fixed/../gcc-4.9.3/gcc/cp/cfns.gperf    2017-04-04
>>>> 14:35:14.729966600 -0400
>>>> File to patch:
>>>> Skip this patch? [y]
>>>> Skipping patch.
>>>> 2 out of 2 hunks ignored
>>>> I'd like to know if I'm interpreting the log correctly.
> The patch is for gcc-4.9.3, but the RSB is trying to apply it to
> newlib. (cd newlib ... patch). So the patch command cannot find the
> file to patch since it is part of the gcc source tree, not of newlib.
> Change your manual modifications from
> %patch add newlib file:///c/opt/rtems/4.11.0/rtems/gcc-4.9.3-20170404-1.patch
> to
> %patch add gcc file://gcc-4.9.3-20170404-1.patch
> -Gedare
>>>> I am building from this directory:
>>>> Can I assume that the script is in the following directory after the
>>>> first command that was logged above?:
>>>> /c/opt/rtems/4.11.0/rtems/build/srg4n2xwm1/newlib-2.2.0.20150423
>>> The patches are in `patches` below `rtems` in the RSB. The script knows
>>>> I can see the target file for the first difference here:
>>>> /c/opt/rtems/4.11.0/rtems/build/srg4n2xwm1/gcc-4.9.3/gcc/cp/cfns.gperf
>>>> Do you have any idea about what I might be doing wrong?
>>> Not yet. I ma creating a box to test on. My Windows VM is busy doing
>>> other things and I have not wanted to update MSYS2 so I have been
>>> building a Windows box to test builds on. Once it is running I will take
>>> a look.
>>> Chris
>> users mailing list
>> users at rtems.org
