RTEMS 4.11.2-rc4 Release
Chris Johns
chrisj at rtems.org
Thu Apr 13 00:48:13 UTC 2017
Hello,
RTEMS 4.11.2-rc4 is available for testing. If you are using RTEMS 4.11.1 we encourage you to test and report any issues before the release date of 15th April 2017. I have again moved the release date to add the patch to build on Windows.
The release is available here:
https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc4/
The release notes contain the issues fixed. Important issues are:
- DOSFS fixes
- Libdl C++ exceptions fixes on 4.12 have been back ported
to the 4.11 branch.
- Windows build patch.
If you find an issue please raise a ticket and set the milestone to 4.11.2.
If you have a question please email this list.
Notes:
1. This release contains release notes for all 4.11 dot releases. The PDF has links in red to RTEMS's Trac so you can click though to Trac to review details.
2. Doxygen documentation is available.
3. I have fixed and tested using an `rc` directory.
Thanks
