RTEMS 4.11.0 build fails on Windows
Linda Huxley lhuxley at shaw.ca
Thu Apr 13 02:19:54 UTC 2017
Thanks Chris,
 > What `prefix` did you supply to the RSB `sb-set-builder` command?
Here is my command line:
$ ../source-builder/sb-set-builder \
     --prefix=/opt/rtems/4.11.0 4.11/rtems-sparc --jobs=none
 >> So I created the "/c/opt/rtems/4.11.0/bin" directory and I copied the
 >> contents of the other bin directory into it.
 > This is what the RSB does, but it only does it if there are no errors.
 > I am confused why you need to do this, the RSB should complete with an
 > installed set of tools.
I didn't see any error messages.  The build on the terminal ended with this:
building: sparc-rtems4.11-kernel-4.11.0-1
reporting: tools/rtems-kernel-4.11.cfg ->
sparc-rtems4.11-kernel-4.11.0-1.txt
sparc-rtems4.11-kernel-4.11.0-1.xml
installing: expat-2.1.0-x86_64-w64-mingw32-1 -> C:\msys64\opt\rtems\4.11.0
installing: sparc-rtems4.11-binutils-2.26-x86_64-w64-mingw32-1 ->
installing:
sparc-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-w64-mingw32-1 ->
installing: sparc-rtems4.11-gdb-7.9-x86_64-w64-mingw32-1 ->
installing: rtems-tools-4.11.0-1 -> C:\msys64\opt\rtems\4.11.0
installing: sparc-rtems4.11-kernel-4.11.0-1 -> C:\msys64\opt\rtems\4.11.0
cleaning: expat-2.1.0-x86_64-w64-mingw32-1
cleaning: sparc-rtems4.11-binutils-2.26-x86_64-w64-mingw32-1
cleaning:
cleaning: sparc-rtems4.11-gdb-7.9-x86_64-w64-mingw32-1
cleaning: rtems-tools-4.11.0-1
cleaning: sparc-rtems4.11-kernel-4.11.0-1
Build Set: Time 2:23:37.136150
/c/opt/rtems/4.11.0/rtems $
 > I have just uploaded RTEMS 4.11.2-rc4 and I suggest you use this. I
 > attach a picture of the build running a Windows10 machine. The
 > 4.11.2-rc4 contains the patch needed to build on Windows.
OK, I'll try that next.
Regards,
Linda
On 2017-04-12 18:44, Chris Johns wrote:
> On 13/4/17 8:53 am, Linda Huxley wrote:
>> The fix recommended by Gedare worked, and my RTEMS tools build completed
>> without incident.
> Great. I have pushed a fix to the RSB on the 4.11 branch.
>> Section "5.2.1. RTEMS Tools and Kernel" of the RTEMS User Manual 4.11.99
>> ends with the following statement:
>> "You can now build a 3rd party library or an application as defailted in
>> TBD."
>> But there are no instructions to build the RTEMS kernel within that
>> section.  Is that what is intended?
> It needs me to write the section. I would like to do this task however I
> have not had time to do this. This work is currently unfunded so it
> happens when I have the time.
>> I went back to section "3. Quick Start" for instructions on how to build
>> the kernel.  The first command for building the kernel is:
>> $ export PATH=$HOME/development/rtems/4.12/bin:$PATH
>> My directory tree is different, so the corresponding command would be:
>> $ export PATH=/c/opt/rtems/4.11.0/bin:$PATH
>> But the preceding tools build did not create that directory.  Is that
>> right?
>> I found the following directory instead:
>> /c/opt/rtems/4.11.0/rtems/build/tmp/sb-Linda/C/msys64/opt/rtems/4.11.0/bin
> This is a temporary directory used by the RSB to package the tools. It
> is not the final directory.
>>  Then I ran the following
>> commands:
>> $ cd /c/opt/rtems
>> $ mkdir kernel
>> $ cd kernel
>> $ git clone git://git.rtems.org/rtems.git rtems
>> $ cd rtems
>> $ ./bootstrap -c && ./bootstrap -p && \
>>   /c/opt/rtems/4.11.0/source-builder/sb-bootstrap
>> $ cd ..
>> $ mkdir erc32
>> $ cd erc32
>> $ /c/opt/rtems/kernel/rtems/configure --prefix=/c/opt/rtems/4.11.0 \
>>   --target=sparc-rtems4.11.0 --enable-rtemsbsp=erc32 --enable-posix
>> $ make -j 8
>> However, the final command failed.  The following errors occurred:
>> In file included from
>> C:/opt/rtems/kernel/rtems/tools/build/cklength.c:27:0:
>> C:/opt/rtems/kernel/rtems/tools/build/cklength.c: In function 'error':
>> C:/opt/rtems/kernel/rtems/tools/build/cklength.c:251:16: warning:
>> '_errno' redeclared without dllimport attribute: previous dllimport
>> ignored [-Wattributes]
>>      extern int errno;
>> C:/opt/rtems/kernel/rtems/tools/build/eolstrip.c:22:0:
>> C:/opt/rtems/kernel/rtems/tools/build/eolstrip.c: In function 'error':
>> C:/opt/rtems/kernel/rtems/tools/build/eolstrip.c:245:16: warning:
>>      extern int errno;
>> In file included from C:/opt/rtems/kernel/rtems/tools/build/unhex.c:36:0:
>> C:/opt/rtems/kernel/rtems/tools/build/unhex.c: In function 'error':
>> C:/opt/rtems/kernel/rtems/tools/build/unhex.c:687:16: warning: '_errno'
>> redeclared without dllimport attribute: previous dllimport ignored
>> [-Wattributes]
>>      extern int errno;
>> Those errors look suspiciously like the problem that I ran into with
>> cfns.h.  Is there perhaps a patch or a fix?
> They are warnings and I see them as well but the build does not stop.
>> Those errors don't terminate the build, but the build fails later with
>> the following error:
>> checking for sparc-rtems4.11.0-gcc... no
>> configure: error: no acceptable cc found in $PATH
> This is the real issue. It is an unfortunate the RTEMS build system does
> not perform a suitable check when the initial configure phase happens.
> Chris
