Doubt about interrupts in xilinx zedboard BSP
Sergio Paracuellos
sparacuellos at orbitalcs.com
Tue Apr 18 07:24:25 UTC 2017
Hi all,
I am trying to exec some code over xilinx-zynq zedboard. The code tries to
make use of interrupts. I am installing the interrupt routine for the
interrupt vector using rtems_interrupt_handler_install routine which is
seems the correct one for this board. When the interrupt is trigered the
handler is correctly called but it becomes in a infinite loop status when
the interrupt is being handled. So is obvious that i am doing something
wrong. The pseudo code for this is like the following:
#include <bsp.h>
#include <rtems/irq.h>
#include <rtems/irq-extension.h>
#define MAX_NUMBER_OF_MESSAGES 5
#define INTERRUPT_VECTOR_NUMBER 100
volatile int seq;
void MyInterruptHandler(void *arg)
puts("Interrupt handler called\n");
seq++;
rtems_task Init(rtems_task_argument argument)
rtems_status_code sc;
sc = rtems_interrupt_handler_install(
INTERRUPT_VECTOR_NUMBER,
"MY_INTERRUPT",
RTEMS_INTERRUPT_UNIQUE,
(rtems_interrupt_handler) MyInterruptHandler,
NULL
if (sc != RTEMS_SUCCESSFUL)
puts("MyInterruptHandler -> rtems_interrupt_handler_install()
error: %d\n", sc);
exit(-1);
puts("Waiting for messages...\n");
/* wait for five interrupts to be triggered */
while (1)
if (seq == MAX_NUMBER_OF_MESSAGES)
break;
puts("Max number of messages retrieved\n");
exit(0);
The result is:
Enters in a infinite loop calling the interrupt handler....
This similar code runs for me in other OS, so i am a little lost. Also, I
couldn't find any example of using interrupts for zedboard.
What is missing in this code?
Thanks in advance,
Cheers,
Sergio Paracuellos
URL: <http://lists.rtems.org/pipermail/users/attachments/20170418/b39ad93d/attachment.html>
