RSB builds single-threaded Newlib by default?
Linda Huxley lhuxley at shaw.ca
Wed Apr 19 00:03:44 UTC 2017
Thanks Joel,
 > Chris can confirm but some (all?) of the gdb simulators do not build
 > on Windows. It is a dependency on UNIX/POSIX APIs that are
 > not available. These could be fixed in the source code but no one
 > has stepped up to do it.
I'll attempt to build an x86 target next and see if I can get it to run
inside of VirtualBox.
Regards,
Linda
On 2017-04-18 12:33, Joel Sherrill wrote:
> On Tue, Apr 18, 2017 at 1:30 PM, Linda Huxley <lhuxley at shaw.ca
> <mailto:lhuxley at shaw.ca>> wrote:
>     Thanks Chris,
>     > The RSB builds the kernel when released. I have not updated the
>     > documentation discuss this.
>     How do I tell if the kernel has been built by RSB?  (I don't
>     understand what it means to build the kernel if each program
>     contains a stand-alone copy of the kernel.  Is the kernel a library,
>     or a set of header files?)  I will delete everything and start
>     another RSB build.
>     > Please download and untar the file to a directory and then run the
>     > configure command:
>     I followed your instructions.  (There was one slight issue.  There
>     was apparently an extra "/rtems/" in the configure path.)  I
>     executed the following commands:
>     $ cd /c/opt/rtems
>     $ tar Jxf rtems-4.11.2-rc4.tar.xz
>     $ mkdir erc32
>     $ cd erc32
>     $ /c/opt/rtems/rtems-4.11.2-rc4/configure \
>         --prefix=/c/opt/rtems/r4.11.2 \
>         --target=sparc-rtems4.11 \
>         --enable-rtemsbsp=erc32 \
>         --enable-posix
>     $ make -j 1
>     $ make install
>     That build completed without complaint.
>     I consulted various RTEMS tutorials, but I could not get the hello
>     world example to run.  I found that hello.exe, (which appears to be
>     an ELF image), had been built here:
>     /c/opt/rtems/erc32/sparc-rtems4.11/c/erc32/testsuites/samples/hello/
>     Some of the tutorials said that I could run the samples with the
>     following command:
>     $ sparc-rtems4.11-run hello.exe
>     But I cannot find any executable or script with the name
>     "sparc-rtems4.11-run".  When I try to run the program using gdb, I
>     see the following:
>     $ sparc-rtems4.11-gdb hello.exe
>     GNU gdb (GDB) 7.9
>     Copyright (C) 2015 Free Software Foundation, Inc.
>     Reading symbols from hello.exe...done.
>     (gdb) tar sim
>     Undefined target command: "sim".  Try "help target".
>     (gdb) help target
>     Connect to a target machine or process.
>     The first argument is the type or protocol of the target machine.
>     Remaining arguments are interpreted by the target protocol.  For more
>     information on the arguments for a particular protocol, type
>     `help target ' followed by the protocol name.
>     List of target subcommands:
>     target core -- Use a core file as a target
>     target exec -- Use an executable file as a target
>     target extended-remote -- Use a remote computer via a serial line
>     target native -- Native process (started by the "run" command)
>     target record-btrace -- Collect control-flow trace and provide the
>     execution history
>     target record-core -- Log program while executing and replay
>     execution from log
>     target record-full -- Log program while executing and replay
>     execution from log
>     target remote -- Use a remote computer via a serial line
>     target tfile -- Use a trace file as a target
>     Type "help target" followed by target subcommand name for full
>     documentation.
>     Type "apropos word" to search for commands related to "word".
>     Command name abbreviations are allowed if unambiguous.
>     (gdb) load
>     You can't do that when your target is `exec'
>     (gdb) r
>     Don't know how to run.  Try "help target".
>     (gdb)
>     It appears that GDB has not been built with a sparc simulator.
>     Regards,
>     Linda
>     On 2017-04-17 22:30, Chris Johns wrote:
>         On 18/04/2017 13:20, Linda Huxley wrote:
>             Hi Chris,
>                 I assume you are building RTEMS by hand.
>             I'm not sure what that means.  These are the commands that I
>             issued
>             after successfully building the 4.11.2-rc4 tools using rsb:
>             $ export PATH=/c/opt/rtems/r4.11.2/bin:$PATH
>             $ cd /c/opt/rtems
>             $ mkdir kernel
>             $ cd kernel
>             $ git clone git://git.rtems.org/rtems.git
>             <http://git.rtems.org/rtems.git> rtems
>         Ah ok, yes you have followed the documentation.
>         You are building the development version of RTEMS and not the 4.11
>         branch. The documentation was written before I made the 4.11
>         releases
>         and it needs updating. I am sorry for this.
>         For git you need to:
>          $ git checkout 4.11
>         Also see below for a tar file of the source to build rather than
>         using git.
>             $ cd rtems
>             $ ./bootstrap -c && ./bootstrap -p && \
>               /c/opt/rtems/r4.11.2/source-builder/sb-bootstrap
>             $ cd ..
>             $ mkdir erc32
>             $ cd erc32
>             $ /c/opt/rtems/kernel/rtems/configure
>               --target=sparc-rtems4.11 --enable-rtemsbsp=erc32
>             --enable-posix
>             $ make -j 1
>                 Which RTEMS did you download?
>             Again, I'm not sure what you're asking.  I just followed the
>             instructions in the Quick Start section of the RTEMS User
>             Manual.  Is
>             this what you're asking for?
>         This is what I am asking. Your RSB command should have built
>         RTEMS for
>         you. The RSB builds the kernel when released. I have not updated the
>         The source for the kernel you can use is:
>         https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc4/rtems-4.11.2-rc4.tar.xz
>         <https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc4/rtems-4.11.2-rc4.tar.xz>
>         configure command:
>          $ cd /c/opt/rtems
>          $ mkdir erc32
>          $ cd erc32
>          $ /c/opt/rtems/rtems-4.11.2-rc4/rtems/configure \
>              --enable-posix
>         Please note there is no need to bootstrap the source. The
>         release are
>         bundled with the needed files.
>                 What is the `configure` command line?
>             Is this what you're looking for?
>             --enable-posix
>         Yes. This is correct, you just need to use the correct source.
>         Again thank you for the reports and helping us see the issue. I have
>         created ticket #2998 to record this issue.
>         Chris
>     _______________________________________________
>     users mailing list
>     users at rtems.org <mailto:users at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/users
>     <http://lists.rtems.org/mailman/listinfo/users>
