SMP questions (CPU core assign & interrupt Management)
Thomas Kim
thomas73.kim at gmail.com
Fri Apr 21 08:47:28 UTC 2017
Dear Sir,
After I completed to test SMP on ZynQ, I am testing SMP on i.MX6Q(Cortex-A9
quad core).
I attached my bspsmp.c code. It is from FreeBSD v11 source
tree(sys/arm/freescale/imx/imx6_mp.c)
I hope that the attached code is useful for everyone.
On referencing, I am beginner about SMP RTEMS. please understand my status.
As I check in rtems example and rtems-libbsd sample code, I guess that CPU
ID assignment is done by RTEMS MPD scheduler automatically according to CPU
load usage. Is it correct ?
At this time, my testing device drivers is manged
using rtems_interrupt_handler_install().
But, I think that rtems_interrupt_handler_install() function have interrupt
handler intializing feature for cpu id 0 only. Is it correct ?
There is senario exmaple in bleow;
CPU ID 0 : task A and Task B is started.
- task A installed interrupt handler for device A.
- task B installed interrupt handler for device B.
CPU ID 1 : task C and Task D is started.
- task C installed interrupt handler for device C.
- task D installed interrupt handler for device D.
CPU ID 2 : task E is started.
- task E installed interrupt handler for device E.
CPU ID 3 : task F is started.
- task F installed interrupt handler for device F.
I guess that even though each tasks install interrupt handler on each core
id, the registered interrupt handlers are managed by core id 0 only.
Is it correct ?
I am confusing that how to manage interrupt handler on each cores ?
Can I use printf() and/or printk() on each cores ?
Please advise me.
Best Regards,
Thomas Kim
URL: <http://lists.rtems.org/pipermail/users/attachments/20170421/164938ab/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170421/164938ab/attachment.bin>
