Bug fix in 'apbuart_cons.c' file ?
Daniel Hellstrom
daniel at gaisler.com
Mon Apr 24 10:41:39 UTC 2017
Hi Charles,
Sorry I missed to reply on your email. Thanks for reminding me. Which
codebase do you use, is it the current RTEMS master or RCC-1.2?
/Daniel
On 2017-04-24 07:50, Charles INGELS wrote:
> Hi Joel,
> until now, I did not receive any answer from Daniel. I do not know if
> my feedback has been taken into account, maybe for other users if they
> have the same issue.
> Nevertheless, the fix seems to work fine with no apparent side effects.
> Regards,
> Charles
> Le 11.04.2017 à 03:29, Joel Sherrill a écrit :
>> I'm going to assume that Daniel didn't see this since he didn't comment.
>> On Apr 10, 2017 2:41 AM, "Charles INGELS" <charles.ingels at syderal.ch
>> <mailto:charles.ingels at syderal.ch>> wrote:
>> Hello,
>> By using the APB Uart BSP on a SPARC LEON3 target, I think that I
>> have found something which seems to be incorrect.
>> In my RTEMS app, I just want to receive data through the UART1.
>> Such data are then echoed on the same interface.
>> When I want to open the '/dev/apbuart1' descriptor, I get a 'No
>> such file or directory' error message. I get the same error
>> message whatever is the descriptor I try to open
>> ('/dev/apbuart0', ...).
>> I am using the driver manager and I have defined the
>> CONFIGURE_DRIVER_AMBAPP_GAISLER_APBUART to have the driver
>> manager create the device descriptors. However, the descriptors
>> are not created.
>> I had a look at the content of the following file :
>> U:\rtems\src2\rtems\c\src\lib\libbsp\sparc\shared\uart\apbuart_cons.c
>> On line #278, the if statement does not explicitly test the value
>> returned by the call to function 'drvmgr_get_dev_prefix()'.
>> Since such function returns 0 in case of success, the content of
>> the if statement is never executed. Consequently, the variable
>> 'priv->devName' is never initialized to the right string
>> '/dev/apbuart%d', it is always empty which seems to explain why
>> the device descriptor is not not created.
>> I have slightly modified the test with the following code :
>> if (drvmgr_get_dev_prefix(dev, prefix) != -1)
>> I explicitly test the returned value against -1 (which is
>> considered as an error). With that code, the '/dev/apbuartX'
>> device descriptors are successfully created and communicate with
>> the UART.
>> So is it a known bug ? Will it be fixed in the next releases ? Is
>> the way I fixed it correct, or no ?
>> Such fix works for me but are there some side effects that shall
>> be taken into account ?
>> Thanks for your answers,
>> Regards,
>> Charles
>> *Charles INGELS*
>> Embedded software expert
>> charles.ingels at syderal.ch <mailto:charles.ingels at syderal.ch>
>> Phone /+41 (0)32 338 99 10 <tel:+41%2032%20338%2099%2010>/
>> iNum /+883 5100 0902 7759/
>> *SYDERAL SA*
>> Neuenburgstrasse 7
>> CH-3238 Gals (Suisse)
>> Desk /+41 (0)32 338 98 00 <tel:+41%2032%20338%2098%2000>/
>> Fax /+41 (0)32 338 99 34 <tel:+41%2032%20338%2099%2034>/
>> Web site http://www.syderal.ch
>> users mailing list
>> users at rtems.org <mailto:users at rtems.org>
>> <http://lists.rtems.org/mailman/listinfo/users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20170424/c554dc3a/attachment-0002.html>
URL: <http://lists.rtems.org/pipermail/users/attachments/20170424/c554dc3a/attachment-0003.html>
