RTEMS 4.11.2-rc3 Release
Needell, Jerry Jerry.Needell at unh.edu
Fri Apr 7 12:44:14 UTC 2017
Chris,
I tried again an  a different Centos7 system but it failed in the same place.
Are you saying that i should not be using ftp.rtems.org at all?
Clearly VERSION points to ftp.rtems.org.
When it fails:
making dir: /home/needell/development/rtems/rtems-source-builder-4.11.2-rc3/rtems/sources
download: ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz -> sources/rtems-tools-4.11.2-rc3.tar.xz
download: ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz: error: <urlopen error ftp error: 550 Failed to change directory.>
error: downloading ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz: all paths have failed, giving up
  See error report: rsb-report-rtems-tools-4.11.2-rc3-1.txt
Build Set: Time 0:12:42.486734
the URLS seem to be missing and “rc” after the”releases/4.11”
That is where the files are found when I download them manually.
Jerry
Jerry Needell -- jerry.needell at unh.edu
University of New Hampshire
Space Science Center
office phone +1 603 862 2732
cell phone    +1 603 969 6723
> On Apr 7, 2017, at 8:08 AM, Needell, Jerry <Jerry.Needell at unh.edu> wrote:
> Is this a problem?
> This is the contents of VERSION in rtems-source-builder-4.11.2-rc3
> [version]
> release = 4.11.2-rc3
> release_path = https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc3/sources
> [hashes]
> rtems-tools-4.11.2-rc3.tar.xz = sha512 ba36a66d399236c1136607c66ad122ac5321474d60e5eafffdffa5744b36668f6ad19322c487a2f3a667c07e588a40e34c004aef01de9cb2c46c374161f524e1
> rtems-4.11.2-rc3.tar.xz = sha512 57edfd0bab984c4bb84f620a31f502dc85b5c59b5065be0705d4e14fcbe36b6b9daa33c442c5c76445b879508ccb6b43245eb1746ef92e22bf9b568f2b585d0e
>> On Apr 7, 2017, at 7:30 AM, Needell, Jerry <Jerry.Needell at unh.edu> wrote:
>> Chris - That is strange:
>> My command line was:
>> ../source-builder/sb-set-builder          --prefix=$HOME/development/rtems/4.11.2-rc3          4.11/rtems-sparc
>> I did find references to ftp.rtems.org   in the source-builder source
>> source-builder]$ grep -r "ftp.rtems" *
>> defaults.mc:rtems_release_url:   none,    none,     'ftp://ftp.rtems.org/pub/rtems/releases/%{rtems_version}’
>> attached is the full build log (gzipped)
>> <rsb-log-20170406-114029.txt.gz>
>> I ‘ll give it another try today.
>> Thanks
>> Jerry
>>> On Apr 6, 2017, at 6:57 PM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 06/04/2017 21:57, Needell, Jerry wrote:
>>>> looks like there is still an issue  with the use of  “rc”  ;-(  :
>>>> attempted build of sprac-rtems via RSB on Centos7
>>>> download:
>>>> https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.2-2Drc3_rtems-2Dtools-2D4.11.2-2Drc3.tar.xz&d=DwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=8Y_ymaeC2x463eWVj6cYOXzkxD2QRHSDoTCRVczwgu0&s=CNH_ub9dR8QuoTKNo0gQJLoSAnPcFYMglt2uV1h2RHs&e= -> sources/rtems-tools-4.11.2-rc3.tar.xz
>>> Where did `https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_&d=DwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=8Y_ymaeC2x463eWVj6cYOXzkxD2QRHSDoTCRVczwgu0&s=Z8wVDXkQtrKd30xB95KMLwrkWl0AfPdiwKOr4oYfjDI&e= ` come from?
>>> What was your command line?
>>> I ask because `https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_&d=DwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=8Y_ymaeC2x463eWVj6cYOXzkxD2QRHSDoTCRVczwgu0&s=Z8wVDXkQtrKd30xB95KMLwrkWl0AfPdiwKOr4oYfjDI&e= ` is not defined in the RSB source anywhere:
>>> $ grep -r 'ftp.rtems.org' config/
>>> config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg:%source set gcc https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.rtems.org_pub_rtems_people_chrisj_nios_nios2-2Dgcc-2D4.1.tar.bz2&d=DwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=8Y_ymaeC2x463eWVj6cYOXzkxD2QRHSDoTCRVczwgu0&s=ha9zLSY8cjKst4pTemZJr_JcVLijTkuwIX3Zo70vLwY&e= config/tools/rtems-nios2-binutils-2.20-1.cfg:%source set binutils https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.rtems.org_pub_rtems_people_chrisj_nios_nios2-2Dbinutils-2D2.20.tar.bz2&d=DwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=8Y_ymaeC2x463eWVj6cYOXzkxD2QRHSDoTCRVczwgu0&s=DlaKBw2_QG53wrwf6DBYHdNKC7MY971dhBkUaLL_3y0&e= config/tools/rtems-nios2-gdb-7.0-1.cfg:%source set gdb https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.rtems.org_pub_rtems_people_chrisj_nios_nios2-2Dgdb-2D7.0.tar.bz2&d=DwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=8Y_ymaeC2x463eWVj6cYOXzkxD2QRHSDoTCRVczwgu0&s=yqzLginqIrSwC4VeB3HWWF4A4P18_W1EFFftK1DHojI&e=
>>> and the path used in the release is defined here:
>>> https://urldefense.proofpoint.com/v2/url?u=https-3A__git.rtems.org_rtems-2Drelease_tree_rtems-2Drelease-2Ddefaults-23n61&d=DwIDaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=8Y_ymaeC2x463eWVj6cYOXzkxD2QRHSDoTCRVczwgu0&s=UBdtltpSyNyU401ud4QmBwB1_5fn0yySksFfPPIfaeM&e=
>>> I am confused as I tested the RC for just this.
>>> Chris
