RTEMS 4.11.2-rc3 Release
Needell, Jerry Jerry.Needell at unh.edu
Sun Apr 9 21:07:04 UTC 2017
In case it is a clue - It does work fine if you manually download rtems-*  but I did fine that if I just manually downloaded rtems-tools then it failed again at the next step.
Once I downloaded them all, it went smoothly.
On Apr 9, 2017, at 5:02 PM, Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>> wrote:
On Apr 9, 2017 3:59 PM, "Needell, Jerry" <Jerry.Needell at unh.edu<mailto:Jerry.Needell at unh.edu>> wrote:
Joel,
Thats just what I am seeing. RC1 worked fine for me as well.
When the build gets to rtems-tools  for RC3 it still seems to be looking in :
...releases/4.11/4.11.2-rc3
rather than
...releases/4.11/rc/4.11.2-rc3
Maybe I’m not imagining this …. ;-)
No you are not.  :)
Chris will wake up soon so should answer shortly. I could manually download rtems-tools but I don't think that's useful at this point. Looks like an rc4 is needed.
Jerry
On Apr 9, 2017, at 4:57 PM, Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>> wrote:
FWIW I just started an rc3 build and I think I have the same issue as Jerry.
This is on rtbf64c and rc1 built find.
config: tools/rtems-tools-4.11-1.cfg
package: rtems-tools-4.11.2-rc3-1
download: ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz<https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.2-2Drc3_rtems-2Dtools-2D4.11.2-2Drc3.tar.xz&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=-RJGSqT6lt1mJzsinOe5WiNp3JcEV33VPwD6lPy0hiY&e=> -> sources/rtems-tools-4.11.2-rc3.tar.xz
download: ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz<https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.2-2Drc3_rtems-2Dtools-2D4.11.2-2Drc3.tar.xz&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=-RJGSqT6lt1mJzsinOe5WiNp3JcEV33VPwD6lPy0hiY&e=>: error: <urlopen error ftp error: 550 Failed to change directory.>
error: downloading ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz<https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.2-2Drc3_rtems-2Dtools-2D4.11.2-2Drc3.tar.xz&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=-RJGSqT6lt1mJzsinOe5WiNp3JcEV33VPwD6lPy0hiY&e=>: all paths have failed, giving up
Build FAILED
  See error report: rsb-report-rtems-tools-4.11.2-rc3-1.txt
Build Set: Time 0:17:03.301321
Build FAILED
The path is wrong. It should be using this directory:
ftp://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc3/<https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=J6n0xK7M0CQo2MR20pDDWdRFin-FKWpWNC9VSwQBGFI&e=>
The /rc/ component is missing.
I hope I am not repeating something Jerry tried to make clear. :)
--joel
On Sun, Apr 9, 2017 at 3:36 PM, Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>> wrote:
On Sun, Apr 9, 2017 at 8:47 AM, Needell, Jerry <Jerry.Needell at unh.edu<mailto:Jerry.Needell at unh.edu>> wrote:
It looks like I am using python 2.7.5 - I can try it again with python3
$ python --version
Python 2.7.5
It was the same on my local VM and the server I used for all my RTEMS testing.
So that's not the culprit.
I’m not sure what your examples below are showing.  I looks like you aborted them after the first successful download of the autoconf tools.
In my trial the first several download/build phases worked fine. It was not until it got to rtems-tools that it failed.
I just looked like at at that point, it lost the “rc” from the search path.
I apparently haven't tried this rc yet.  But looking in the rc1 tools build log, I see this:
download: ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc1/rtems-tools-4.11.2-rc1.tar.xz<https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.2-2Drc1_rtems-2Dtools-2D4.11.2-2Drc1.tar.xz&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=tXYE_P6GTAzX787d5grcV5RKrqk4dv9aMS0MSSTICDE&e=> -> sources/rtems-tools-4.11.2-rc1.tar.xz
^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 0.0 bytes of 1.6MB (0%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 256.0kB of 1.6MB (15%)  ^H^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 512.0kB of 1.6MB (30%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 768.0kB of 1.6MB (46%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 1.0MB of 1.6MB (61%)   ^H^H^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 1.2MB of 1.6MB (76%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 1.5MB of 1.6MB (92%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 1.6MB of 1.6MB (100%)
^Mbuilding: rtems-tools-4.11.2-rc1-1
reporting: tools/rtems-tools-4.11-1.cfg -> rtems-tools-4.11.2-rc1-1.txt
reporting: tools/rtems-tools-4.11-1.cfg -> rtems-tools-4.11.2-rc1-1.xml
config: tools/rtems-kernel-4.11.cfg
package: sparc-rtems4.11-kernel-4.11.2-rc1-1
download: ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc1/rtems-4.11.2-rc1.tar.xz<https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_releases_4.11_4.11.2-2Drc1_rtems-2D4.11.2-2Drc1.tar.xz&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=f2nxwPsz5-CBNEGjdIGgCWxuE4tOeiznxhhMP96-AzA&e=> -> sources/rtems-4.11.2-rc1.tar.xz
--joel
> On Apr 8, 2017, at 7:29 PM, Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>> wrote:
> On 9/4/17 8:18 am, Chris Johns wrote:
>> The VERSION INI file that is embedded in the RC's RSB package should
>> contain a `release_url` key/value pair that points to the RC sources on
>> ftp.rtems.org<https://urldefense.proofpoint.com/v2/url?u=http-3A__ftp.rtems.org&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=1PGl6SdlGYShA-DTWYiHtsIwyBbc8TnSsuT7uTbo1rE&e=> using the https protocol.
>> This raises a couple of questions, there is still a bug in the get_file
>> function in download.py, and why do I not see this on FreeBSD yet you
>> see it on CentOS7?
> Are you using Python3? Python3 is working for me on FreeBSD.
> The following is running on FreeBSD:
> ruru 4.11 $ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
> https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_rtems-2Dsource-2Dbuilder-2D4.11.2-2Drc3.tar.xz&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=V9PHHtqU_Ji9DqDDyy2R3Qfz3W-2acnkhW3tR8Pt1vE&e=
>  % Total    % Received % Xferd  Average Speed   Time    Time     Time
> Current
>                                 Dload  Upload   Total   Spent    Left
> Speed
> 100  945k  100  945k    0     0   314k      0  0:00:03  0:00:03 --:--:--
> 314k
> ruru 4.11 $ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
> ruru 4.11 $ cd rtems-source-builder-4.11.2-rc3/rtems
> ruru rtems $ ../source-builder/sb-set-builder
> --prefix=/opt/work/rtems/4.11 --log=x.txt 4.11/rtems-arm
> RTEMS Source Builder - Set Builder, 4.11.2-rc3
> Build Set: 4.11/rtems-arm
> Build Set: 4.11/rtems-autotools.bset
> Build Set: 4.11/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cf<https://urldefense.proofpoint.com/v2/url?u=http-3A__rtems-2Dautoconf-2D2.69-2D1.cf&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=4oQVvanf6R_iF5xEpHENEaXg-Vl9cFuyKElK_GwHI7I&e=>g
> package: autoconf-2.69-x86_64-freebsd11.0-1
> Creating source directory: sources
> download:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_sources_autoconf-2D2.69.tar.gz&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=vfEvq_qT-FoLJOMOqW0vv09LxNOVCpYt7qv5yAv3YTc&e=
> -> sources/autoconf-2.69.tar.gz
> downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
> building: autoconf-2.69-x86_64-freebsd11.0-1
> ^CBuild Set: Time 0:00:05.408384
> Build Set: Time 0:00:05.409491
> Build Set: Time 0:00:05.412494
> abort: user terminated
> And with python3:
> ruru rtems $ rm sources/*
> ruru rtems $ python3 ../source-builder/sb-set-builder
> download:
> downloading: sources/autoconf-2.69.tar.gz - 768.0kB of 1.8MB (41%) ^C
> download:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_sources_autoconf-2D2.69.tar.gz-3A&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=XqWn4NqF941OdUy1N5clcqwQo8nxlAReRw69wLZisJI&e=
> error
> download:
> error
> Build Set: Time 0:00:06.209305
> Build Set: Time 0:00:06.210446
> Build Set: Time 0:00:06.213511
> And on OSX:
> huia:releases chris$ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
> Current
> Speed
> 100  945k  100  945k    0     0   291k      0  0:00:03  0:00:03 --:--:--
> 291k
> huia:releases chris$ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
> huia:releases chris$ cd rtems-source-builder-4.11.2-rc3/rtems/
> huia:rtems chris$ ../source-builder/sb-set-builder --no-install
> package: autoconf-2.69-x86_64-apple-darwin16.5.0-1
> download:
> building: autoconf-2.69-x86_64-apple-darwin16.5.0-1
> ^CBuild Set: Time 0:00:08.126000
> Build Set: Time 0:00:08.126978
> Build Set: Time 0:00:08.129516
> Chris
> users mailing list
> users at rtems.org<mailto:users at rtems.org>
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=73IyA2Tz5fAxGmytPuWZ2bjTImhzcvKNEZc0W-ptetU&e=
users mailing list
http://lists.rtems.org/mailman/listinfo/users<https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=6tkoc6nHYm3gqmE43I-JSTjGoFvAljE3AtySpazXyRM&s=KzbdTTpu5iIK80rX7xsDEAQ4hQzok84j_YqSr1SzdE4&e=>
URL: <http://lists.rtems.org/pipermail/users/attachments/20170409/18ec852f/attachment-0002.html>
