Doubt about interrupts in xilinx zedboard BSP
Sergio Paracuellos sparacuellos at orbitalcs.com
Tue Apr 18 08:54:10 UTC 2017
2017-04-18 10:15 GMT+02:00 Thomas Doerfler <
thomas.doerfler at embedded-brains.de>:
> Hi,
Hi,
> does this link help?
> https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/
> Zynq-Clear-Pending-SGI/td-p/747038
Of course it helps :) Thank you very much. I am going to check this.
> wkr,
> Thomas.
Cheers,
    Sergio Paracuellos
> Am 18.04.2017 um 10:11 schrieb Sergio Paracuellos:
> > 2017-04-18 9:28 GMT+02:00 Thomas Doerfler
> > <thomas.doerfler at embedded-brains.de
> > <mailto:thomas.doerfler at embedded-brains.de>>:
> >     Hi,
> > Hi,
> >     what kind of interrupt source do you have? I assume that the
> intterrupt
> >     source keeps it interrupt request active, until you have done
> something
> >     in the interrupt source registers that makes the interrupt inactive
> >     again.
> > The interrupt is a Software Generated Interrupt one which uses SGI0 HW
> IRQ.
> > The interrupt pending bit for the vector is being cleared in
> > bsp_interrupt_dispatch() routine for the arm's based bsp's.
> > It should be enough to get this working, but it seems it is not.
> > Something that I have to keep in mind?
> >     Example: If you interrupt source is a UART receiver, the interrupt
> >     request usually stays active until you have pulled all the received
> UART
> >     bytes from the UART receive data register...
> >     wkr,
> >     Thomas.
> > Cheers,
> >     Sergio Paracuellos
> >     Am 18.04.2017 um 09:24 schrieb Sergio Paracuellos:
> >     > Hi all,
> >     > I am trying to exec some code over xilinx-zynq zedboard. The code
> >     tries
> >     > to make use of interrupts. I am installing the interrupt routine
> >     for the
> >     > interrupt vector  using rtems_interrupt_handler_install routine
> >     which is
> >     > seems the correct one for this board. When the interrupt is
> >     trigered the
> >     > handler is correctly called but it becomes in a infinite loop
> status
> >     > when the interrupt is being handled. So is obvious that i am doing
> >     > something wrong. The pseudo code for this is like the following:
> >     > #include <bsp.h>
> >     > #include <stdlib.h>
> >     > #include <rtems/irq.h>
> >     > #include <rtems/irq-extension.h>
> >     > #define MAX_NUMBER_OF_MESSAGES 5
> >     > #define INTERRUPT_VECTOR_NUMBER 100
> >     > volatile int seq;
> >     > void MyInterruptHandler(void *arg)
> >     >     puts("Interrupt handler called\n");
> >     >     seq++;
> >     > rtems_task Init(rtems_task_argument argument)
> >     >     rtems_status_code sc;
> >     >     sc = rtems_interrupt_handler_install(
> >     >                            INTERRUPT_VECTOR_NUMBER,
> >     >                            "MY_INTERRUPT",
> >     >                            RTEMS_INTERRUPT_UNIQUE,
> >     >                            (rtems_interrupt_handler)
> >     MyInterruptHandler,
> >     >                             NULL
> >     >      if (sc != RTEMS_SUCCESSFUL)
> >     >            puts("MyInterruptHandler ->
> >     rtems_interrupt_handler_install()
> >     > error: %d\n", sc);
> >     >            exit(-1);
> >     >      puts("Waiting for messages...\n");
> >     >      /* wait for five interrupts to be triggered */
> >     >     while (1)
> >     >           if (seq == MAX_NUMBER_OF_MESSAGES)
> >     >               break;
> >     >      puts("Max number of messages retrieved\n");
> >     >      exit(0);
> >     > The result is:
> >     > Enters in a infinite loop calling the interrupt handler....
> >     > This similar code runs for me in other OS, so i am a little lost.
> >     Also,
> >     > I couldn't find any example of using interrupts for zedboard.
> >     > What is missing in this code?
> >     > Thanks in advance,
> >     > Cheers,
> >     >     Sergio Paracuellos
> >     > _______________________________________________
> >     > users mailing list
> >     > users at rtems.org <mailto:users at rtems.org>
> >     > http://lists.rtems.org/mailman/listinfo/users
> >     <http://lists.rtems.org/mailman/listinfo/users>
> >     embedded brains GmbH
> >     Thomas Doerfler
> >     Dornierstr. 4
> >     D-82178 Puchheim
> >     Germany
> >     email: Thomas.Doerfler at embedded-brains.de
> >     <mailto:Thomas.Doerfler at embedded-brains.de>
> >     Phone: +49-89-18 94 741-12 <tel:%2B49-89-18%2094%20741-12>
> >     Fax:   +49-89-18 94 741-09 <tel:%2B49-89-18%2094%20741-09>
> >     PGP: Public key available on request.
> >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> >     users mailing list
> Thomas Doerfler
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20170418/472c2fe5/attachment-0002.html>
