RSB builds single-threaded Newlib by default?
Tue Apr 18 18:33:56 UTC 2017
On Tue, Apr 18, 2017 at 1:30 PM, Linda Huxley <lhuxley at shaw.ca> wrote:
> Thanks Chris,
> > The RSB builds the kernel when released. I have not updated the
> > documentation discuss this.
> How do I tell if the kernel has been built by RSB?  (I don't understand
> what it means to build the kernel if each program contains a stand-alone
> copy of the kernel.  Is the kernel a library, or a set of header files?)  I
> will delete everything and start another RSB build.
> > Please download and untar the file to a directory and then run the
> > configure command:
> I followed your instructions.  (There was one slight issue.  There was
> apparently an extra "/rtems/" in the configure path.)  I executed the
> following commands:
> $ cd /c/opt/rtems
> $ tar Jxf rtems-4.11.2-rc4.tar.xz
> $ mkdir erc32
> $ cd erc32
> $ /c/opt/rtems/rtems-4.11.2-rc4/configure \
>     --prefix=/c/opt/rtems/r4.11.2 \
>     --target=sparc-rtems4.11 \
>     --enable-rtemsbsp=erc32 \
>     --enable-posix
> $ make -j 1
> $ make install
> That build completed without complaint.
> I consulted various RTEMS tutorials, but I could not get the hello world
> example to run.  I found that hello.exe, (which appears to be an ELF
> image), had been built here:
> /c/opt/rtems/erc32/sparc-rtems4.11/c/erc32/testsuites/samples/hello/
> Some of the tutorials said that I could run the samples with the following
> command:
> $ sparc-rtems4.11-run hello.exe
> But I cannot find any executable or script with the name
> "sparc-rtems4.11-run".  When I try to run the program using gdb, I see the
> following:
> $ sparc-rtems4.11-gdb hello.exe
> GNU gdb (GDB) 7.9
> Copyright (C) 2015 Free Software Foundation, Inc.
> Reading symbols from hello.exe...done.
> (gdb) tar sim
> Undefined target command: "sim".  Try "help target".
Chris can confirm but some (all?) of the gdb simulators do not build
on Windows. It is a dependency on UNIX/POSIX APIs that are
not available. These could be fixed in the source code but no one
has stepped up to do it.
> (gdb) help target
> Connect to a target machine or process.
> The first argument is the type or protocol of the target machine.
> Remaining arguments are interpreted by the target protocol.  For more
> information on the arguments for a particular protocol, type
> `help target ' followed by the protocol name.
> List of target subcommands:
> target core -- Use a core file as a target
> target exec -- Use an executable file as a target
> target extended-remote -- Use a remote computer via a serial line
> target native -- Native process (started by the "run" command)
> target record-btrace -- Collect control-flow trace and provide the
> execution history
> target record-core -- Log program while executing and replay execution
> from log
> target record-full -- Log program while executing and replay execution
> from log
> target remote -- Use a remote computer via a serial line
> target tfile -- Use a trace file as a target
> Type "help target" followed by target subcommand name for full
> documentation.
> Type "apropos word" to search for commands related to "word".
> Command name abbreviations are allowed if unambiguous.
> (gdb) load
> You can't do that when your target is `exec'
> (gdb) r
> Don't know how to run.  Try "help target".
> (gdb)
> It appears that GDB has not been built with a sparc simulator.
> Regards,
> Linda
> On 2017-04-17 22:30, Chris Johns wrote:
>> On 18/04/2017 13:20, Linda Huxley wrote:
>>> Hi Chris,
>>> I assume you are building RTEMS by hand.
>>> I'm not sure what that means.  These are the commands that I issued
>>> after successfully building the 4.11.2-rc4 tools using rsb:
>>> $ export PATH=/c/opt/rtems/r4.11.2/bin:$PATH
>>> $ cd /c/opt/rtems
>>> $ mkdir kernel
>>> $ cd kernel
>>> $ git clone git://git.rtems.org/rtems.git rtems
>> Ah ok, yes you have followed the documentation.
>> You are building the development version of RTEMS and not the 4.11
>> branch. The documentation was written before I made the 4.11 releases
>> and it needs updating. I am sorry for this.
>> For git you need to:
>>  $ git checkout 4.11
>> Also see below for a tar file of the source to build rather than using
>> git.
>> $ cd rtems
>>> $ ./bootstrap -c && ./bootstrap -p && \
>>>   /c/opt/rtems/r4.11.2/source-builder/sb-bootstrap
>>> $ cd ..
>>> $ mkdir erc32
>>> $ cd erc32
>>> $ /c/opt/rtems/kernel/rtems/configure --prefix=/c/opt/rtems/r4.11.2 \
>>>   --target=sparc-rtems4.11 --enable-rtemsbsp=erc32 --enable-posix
>>> $ make -j 1
>>> Which RTEMS did you download?
>>> Again, I'm not sure what you're asking.  I just followed the
>>> instructions in the Quick Start section of the RTEMS User Manual.  Is
>>> this what you're asking for?
>> This is what I am asking. Your RSB command should have built RTEMS for
>> you. The RSB builds the kernel when released. I have not updated the
>> The source for the kernel you can use is:
>> https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc4/
>> configure command:
>>  $ cd /c/opt/rtems
>>  $ mkdir erc32
>>  $ cd erc32
>>  $ /c/opt/rtems/rtems-4.11.2-rc4/rtems/configure \
>>      --enable-posix
>> Please note there is no need to bootstrap the source. The release are
>> bundled with the needed files.
>> What is the `configure` command line?
>>> Is this what you're looking for?
>> Yes. This is correct, you just need to use the correct source.
>> Again thank you for the reports and helping us see the issue. I have
>> created ticket #2998 to record this issue.
>> Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170418/8a91c67a/attachment-0002.html>
