Porting RTEMS on Arm Cortex-M1
Daniel Jones daniel.jones1400 at gmail.com
Sat Apr 22 11:47:49 UTC 2017
Hello Sir
Thank you for your response. Memory is no problem. I am starting with
armv7-m bsp. But still have some question left and I hope someone could
help. What about the rtems start code, context switch, exception handle and
other similar files which I have found for armv4 and armv7-m? Do I have to
write these supports for armv6-m? As armv6-m and armv7-m are not that much
different, in which files I have to make some changes? Any sort of help is
appreciated.
Regards
Daniel
URL: <http://lists.rtems.org/pipermail/users/attachments/20170422/c15e1a43/attachment-0002.html>
