Is there a way to do dynamic loading using the 'rtems_task_create' function?
jaeho jo
hot486two at gmail.com
Wed Aug 2 01:19:38 UTC 2017
Hi
I have two question on dynamic load
1. Is there a way to do dynamic loading using the 'rtems_task_create'
function?
In my method, I used 'dlsym' to get the address where that symbol is
loaded into memory and call the task using function pointer
[my code]
typedef int (*call_t)(int argc, char* argv[]);
call = dlsym (handle, call_symbol);
call(argc,argv);
2. I used 'rtems-ld' to create a RAP and set entry point with option '-e'
Also, I called 'dlopen', 'dlsym' to load task dynamically in source code
level.
In 'dlsym', I need to set entry point(symbol),which is the same as the
entry point used in 'rtems-ld'
I think this is a duplicate command.
Is there a way to improve it?
URL: <http://lists.rtems.org/pipermail/users/attachments/20170802/45a7af73/attachment.html>
