RTEMS Toolchain building failed
Jianxun Yan
yanjx at jlab.org
Fri Aug 18 19:08:51 UTC 2017
I used to be able to build both 4.11 and 4.12. But, when I tried to
rebuild the 4.12, it got failed. Does the master have anything changed?
Jay
On 08/18/2017 02:55 PM, Jacob Saina wrote:
> I have the same result. I used to be able to build from the 4.11 tag,
> so I assume something is wrong with the current master.
> On Fri, Aug 18, 2017 at 2:50 PM, Jianxun Yan <yanjx at jlab.org
> <mailto:yanjx at jlab.org>> wrote:
> Hi,
> I tried to build RTEMS 4.12 toolchain, but failed.
> > ../source-builder/sb-set-builder
> --prefix=/group/eesicgrp/yanjx/development/rtems/4.12 4.12/rtems-arm
> RTEMS Source Builder - Set Builder, 4.12 (7208ab69e1fc)
> Build Set: 4.12/rtems-arm
> Build Set: 4.12/rtems-autotools.bset
> Build Set: 4.12/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cf
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__rtems-2Dautoconf-2D2.69-2D1.cf&d=DwMFaQ&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=C3EDzt-0O9of34Y0IF-Dug&m=Hvxh3QuOFMS5KqRDagQe9YikCrt3YDhWq4JlLLcbu34&s=qnGxGZUOUPm1Kl0UfKcuoMRZsJw_fYGgJLFMdWeIkPE&e=>g
> git: pull: git://git.rtems.org/rtems-tools.git
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__git.rtems.org_rtems-2Dtools.git&d=DwMFaQ&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=C3EDzt-0O9of34Y0IF-Dug&m=Hvxh3QuOFMS5KqRDagQe9YikCrt3YDhWq4JlLLcbu34&s=wsO7eA12LXOmdctgsPfsKgjNaHlRueuIh2bFEYkRK8o&e=>
> building: rtems-tools-HEAD-1
> error: building rtems-tools-HEAD-1
> Build FAILED
> See error report: rsb-report-rtems-tools-HEAD-1.txt
> Build Set: Time 0:50:33.463151
> Build FAILED
> Does anyone know what is the problem?
> Thanks
> Jay
> users mailing list
> users at rtems.org <mailto:users at rtems.org>
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=C3EDzt-0O9of34Y0IF-Dug&m=Hvxh3QuOFMS5KqRDagQe9YikCrt3YDhWq4JlLLcbu34&s=M-Mcn2uu0-BLU0RXFQJQ9HqvTVlusakLaUVkFKSIoao&e=>
URL: <http://lists.rtems.org/pipermail/users/attachments/20170818/0e815f8c/attachment.html>
