RTEMS Toolchain building failed
Jacob Saina
jsaina at terpmail.umd.edu
Fri Aug 18 20:05:01 UTC 2017
The 4.11 tag also fails in the same place. My guess is that something is
wrong with the last update to the rtems-tools submodule with the update to
libiberty on Wed, Aug 16. I'm not familiar enough with the build system to
test this, though.
On Fri, Aug 18, 2017 at 3:08 PM, Jianxun Yan <yanjx at jlab.org> wrote:
> I used to be able to build both 4.11 and 4.12. But, when I tried to
> rebuild the 4.12, it got failed. Does the master have anything changed?
> Jay
> On 08/18/2017 02:55 PM, Jacob Saina wrote:
> I have the same result. I used to be able to build from the 4.11 tag, so I
> assume something is wrong with the current master.
> On Fri, Aug 18, 2017 at 2:50 PM, Jianxun Yan <yanjx at jlab.org> wrote:
>> Hi,
>> I tried to build RTEMS 4.12 toolchain, but failed.
>> > ../source-builder/sb-set-builder --prefix=/group/eesicgrp/yanjx/development/rtems/4.12
>> 4.12/rtems-arm
>> RTEMS Source Builder - Set Builder, 4.12 (7208ab69e1fc)
>> Build Set: 4.12/rtems-arm
>> Build Set: 4.12/rtems-autotools.bset
>> Build Set: 4.12/rtems-autotools-internal.bset
>> config: tools/rtems-autoconf-2.69-1.cf
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__rtems-2Dautoconf-2D2.69-2D1.cf&d=DwMFaQ&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=C3EDzt-0O9of34Y0IF-Dug&m=Hvxh3QuOFMS5KqRDagQe9YikCrt3YDhWq4JlLLcbu34&s=qnGxGZUOUPm1Kl0UfKcuoMRZsJw_fYGgJLFMdWeIkPE&e=>
>> g
>> git: pull: git://git.rtems.org/rtems-tools.git
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__git.rtems.org_rtems-2Dtools.git&d=DwMFaQ&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=C3EDzt-0O9of34Y0IF-Dug&m=Hvxh3QuOFMS5KqRDagQe9YikCrt3YDhWq4JlLLcbu34&s=wsO7eA12LXOmdctgsPfsKgjNaHlRueuIh2bFEYkRK8o&e=>
>> building: rtems-tools-HEAD-1
>> error: building rtems-tools-HEAD-1
>> Build FAILED
>> See error report: rsb-report-rtems-tools-HEAD-1.txt
>> Build Set: Time 0:50:33.463151
>> Build FAILED
>> Does anyone know what is the problem?
>> Thanks
>> Jay
>> users mailing list
>> users at rtems.org
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=lz9TcOasaINaaC3U7FbMev2lsutwpI4--09aP8Lu18s&r=C3EDzt-0O9of34Y0IF-Dug&m=Hvxh3QuOFMS5KqRDagQe9YikCrt3YDhWq4JlLLcbu34&s=M-Mcn2uu0-BLU0RXFQJQ9HqvTVlusakLaUVkFKSIoao&e=>
URL: <http://lists.rtems.org/pipermail/users/attachments/20170818/689ee9ff/attachment.html>
