RTEMS Toolchain building failed
Sat Aug 19 03:22:49 UTC 2017
> On 19 Aug 2017, at 4:50 am, Jianxun Yan <yanjx at jlab.org> wrote:
> Hi,
> I tried to build RTEMS 4.12 toolchain, but failed.
> > ../source-builder/sb-set-builder --prefix=/group/eesicgrp/yanjx/development/rtems/4.12 4.12/rtems-arm
> RTEMS Source Builder - Set Builder, 4.12 (7208ab69e1fc)
> Build Set: 4.12/rtems-arm
> Build Set: 4.12/rtems-autotools.bset
> Build Set: 4.12/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> git: pull: git://git.rtems.org/rtems-tools.git
> building: rtems-tools-HEAD-1
> error: building rtems-tools-HEAD-1
> Build FAILED
>  See error report: rsb-report-rtems-tools-HEAD-1.txt
> Build Set: Time 0:50:33.463151
> Build FAILED
> Does anyone know what is the problem?
I broke rtems-tools on Linux with my last commit. I am on the road at the moment and will fix as soon as I can.
Could you please raise a ticket in Trac and assign to me?
Thanks
