Rtems-libbsd Networking Failed on Altcycv_devkit
Jianxium Yan yanjx at jlab.org
Wed Aug 23 20:30:44 UTC 2017
Hi,
I tried to run the rtems-libbsd networking testsuite samples on Altcycv_devkit board with RTEMS4.12, and found it is failed. The following is the message on the console.
Attached is my network-config.h file. Does anyone know how to fix it?
SOCFPGA_CYCLONE5 # fatload mmc 0:1 0x300000 ftpd01.bin
reading ftpd01.bin
3398976 bytes read in 162 ms (20 MiB/s)
SOCFPGA_CYCLONE5 # go 0x300040
## Starting application at 0x00300040 ...
*** LIBBSD FTPD 1 TEST ***
RTEMS Shell on /dev/console. Use 'help' to list commands.
[/] # xus0: <RTEMS Nexus device>
dw_mmc0: <DesignWare Mobile Storage Host> on nexus0
mmc0: <MMC/SD bus> on dw_mmc0
mmcsd0: 16GB <SDHC SS16G 8.0 SN 0DCF4A42 MFG 04/2016 by 3 SD> at mmc0 50.0MHz/4bit/1-block
dwcotg0: <DWC OTG 2.0 integrated USB controller> on nexus0
usbus0 on dwcotg0
dwc0: <Gigabit Ethernet Controller> on nexus0
miibus0: <MII bus> on dwc0
micphy0: <Micrel KSZ9031 10/100/1000 PHY> PHY 1 on miibus0
micphy0:  none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto
emerg: assertion "0" failed: file "../../freebsd/sys/dev/mii/micphy.c", line 286, function: micphy_attach
Thanks,
Jay Yan
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170823/16bc18d7/attachment.bin>
