Infinite loop on _Heap_Allocate
Jiri Gaisler
jiri at gaisler.se
Thu Aug 24 08:28:54 UTC 2017
Have you applied leon3 patches for qemu from https://gaisler.org/qemu ?
These are needed to boot RTEMS binaries properly.
Jiri.
On 08/24/2017 10:22 AM, LOPEZ CUEVA Patricia wrote:
> Hello all !
> I’ve just installed rtems-4.8 on a Redhat 7 64 bits machine. I’ve
> installed the release version of rtems 4.8 and the following versions
> of the toolset:
> - gcc 4.2.1 with newlib 1.15.0
> - binutils 2.18
> - gdb 6.8
> The compilation and installation of the toolset and rtems run without
> problem except for the documentation part which I disabled.
> Then I installed the rtems-4.8 examples and tried to run hello_world_c
> on qemu leon3 with the command “qemu-system-sparc -nographic -M
> leon3_generic -cpu LEON3 -kernel hello.exe -s –S”.
> Neither error nor warning was present in the compilation or the
> execution process (nor the hello world message) and when I stop the
> execution it is always on the _Heap_Allocate function of
> cpukit/score/src/heapallocate.c file. Here is the backtrace:
> (gdb) c
> Continuing.
> Program received signal SIGINT, Interrupt.
> _Heap_Allocate (the_heap=0x40013e6c, size=<value optimized out>) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/score/src/heapallocate.c:57
> 57 the_block = the_block->next, ++search_count)
> (gdb) bt
> #0 _Heap_Allocate (the_heap=0x40013e6c, size=<value optimized out>)
> at
> #1 0x4000b8c8 in _Workspace_Allocate_or_fatal_error (size=52) at
> ../../cpukit/../../../leon3/lib/include/rtems/score/wkspace.inl:37
> #2 0x4000b2e4 in _User_extensions_Handler_initialization
> (number_of_extensions=1, initial_extensions=0x40012cc0) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/score/src/userext.c:37
> #3 0x40007860 in rtems_initialize_executive_early
> (configuration_table=0x40013930, cpu_table=0x40013908) at
> ../../../../../../rtems-4.8.0/c/src/../../cpukit/sapi/src/exinit.c:152
> #4 0x40001924 in boot_card (argc=0, argv=0x0, envp=0x0) at
> ../../../../../../../../rtems-4.8.0/c/src/lib/libbsp/sparc/leon3/../../shared/bootcard.c:117
> #5 0x400010dc in zerobss () at
> ../../../../../../../../rtems-4.8.0/c/src/lib/libbsp/sparc/leon3/../../sparc/shared/start.S:339
> #6 0x400010dc in zerobss () at
> Backtrace stopped: previous frame identical to this frame (corrupt stack?)
> (gdb) p *the_heap
> $17 = {free_list = {prev_size = 0, size = 0, next = 0xfffc8040, prev =
> 0xfffc8040}, page_size = 8, min_block_size = 16, begin = 0xfffc8040,
> end = 0xfffd5e50, start = 0xfffc8040, final = 0xfffd5e48, stats =
> {instance = 0,
> size = 56848, free_size = 56840, min_free_size = 56840,
> free_blocks = 1, max_free_blocks = 1, used_blocks = 0, max_search = 0,
> allocs = 0, searches = 0, frees = 0, resizes = 0}}
> It seems to be blocked on an infinite loop. I presume there has been a
> problem with the installation of rtems that I have not seen since this
> is a well proven version and it is the most basic example.
> Would you have an idea of what the problem might be?
> Thanks a lot in advance,
> Patricia Lopez Cueva
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170824/eb3884fa/attachment.html>
