How to change RTEMS real time interrupt source to external pin of LEON UT699
Richard.Glossop at L3T.com Richard.Glossop at L3T.com
Wed Aug 30 14:07:50 UTC 2017
Want to change the source of RTEMS time tick interrupt from Timer 0 on the LEON to a GPIO pin.  Have had success enabling the GPIO pin for the interrupt source (I get Spurious Interrupt 5 messages on the gdb console - we are using GPIO 5 - this tells me the interrupt is happening).  When I try to use rtems_interrupt_catch to install a new vector isr for the GPIO, the system crashes.
Here is the code:
rtems_isr_entry reMapRealTimeInterrupt (void)
    int level;
    rtems_isr_entry old_handler;
    rtems_status_code retVal;
    rtems_interrupt_disable (level);     // disable all maskable interrupts
    retVal = rtems_interrupt_catch(         // re-map vector 5 to our handler (GPIO 5)
        handler,
        5,
        &old_handler);
    printf("Remap retVal:0x%x\n",retVal);
    *(unsigned int*)TIMCTR1 &= ~0x00000009; // disable timer 1 interrupt enable and timer enable
    *(unsigned int*)IMR &= ~0x00000040;     // mask interrupt for timer 1 interrupt since it is no longer used
    *(unsigned int*)IMR |=  0x00000020;     // enable GPIO 5 interrupt in IMR
    *(unsigned int*)ILR |=  0x00000020;     // set interrupt 5 to be a level 1 interrupt
    *(unsigned int*)GPIOIMR |= 0x00000020;  // enable bit 5 to cause interrupts (GPIO 5)
    *(unsigned int*)GPIOIER |= 0x00000020;  // set GPIO interrupt 5 to be edge triggered
    *(unsigned int*)GPIOIPR |= 0x00000020;  // set GPIO interrupt 5 to be rising edge
    rtems_interrupt_enable (level);       // enable all previously enabled interrupts
    return old_handler;                      // return original isr address in case want to restore
    rtems_isr handler (rtems_vector_number vector)
        printf("This is irq %d.\n",vector);
        rtems_clock_tick();
Can anyone help with this, or point me to example code to accomplish the same thing?
Effective immediately my new email address is Richard.Glossop at L3T.com. Please update your records.
URL: <http://lists.rtems.org/pipermail/users/attachments/20170830/595910a3/attachment.html>
