Malloc from ISR?
Joel Sherrill
joel at rtems.org
Tue Dec 12 02:12:15 UTC 2017
See cpukit/libcsupport/src/malloc_deferred.c. It is definitely returning
NULL because
you shouldn't malloc from an ISR. malloc() is a non-deterministic
operation. I am
surprised that code was designed to do that.
Perhaps this code assumes the USB interrupt is serviced from a thread. The
raw
interrupt unblocks a thread to run this code.
--joel
On Mon, Dec 11, 2017 at 6:36 PM, Mr. Andrei Chichak <groups at chichak.ca>
wrote:
> (sorry if this ended up on the Devel list.)
> I’m working with ST’s HAL USB stack, and to initialize the various
> structures, they use a USB interrupt as a trigger.
> In this interrupt, they malloc some space for a descriptor (504 bytes).
> The RTEMS malloc always returns 0.
> Is there a guard against calling malloc in an interrupt context?
> I managed to get around the problem by doing a static allocation, but I
> was just wondering.
> Andrei
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20171211/761402b5/attachment.html>
