RTEMS 4.11.2 building troubles on Windows10
茂呂 智志
s_moro at aes.co.jp
Mon Dec 18 08:46:26 UTC 2017
Hello all,
I’m attempting to build the RTEMS tool set
following “RTEMS User Manual” amd “RTEMS Source Builder” on Windows10,
MinGW64.exe.
I have done following commands,
cd /c
mkdir -p opt/rtems
cd opt/rtems
wget
https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2/rtems-source-builder-4.
11.2.tar.xz
tar -Jxvf rtems-source-builder-4.11.2.tar.xz
mv rtems-source-builder-4.11.2 4.11.2
cd 4.11.2
I have 2 troubles.
1. Then, I have done following command,
./rtems-source-builder/sb-check --jobs=none
Result,
RTEMS Source Builder -Set Builder, 4.11.not_released
Environment is ok
What dose “4.11.not_released” mean and is the cause of
“4.11.not_released”?
2. Likewise, I have done following command,
./rtems-source-builder/sb-set-builder --prefix=/opt/rtems/4.11
4.11/rtems-arm --jobs=none
Result,
RTEMS Source Builder - Set Builder, 4.11.not-released
Build Set: 4.11/rtems-arm
error: no build set file found: 4.11/rtems-arm.bset
Build Set: Time 0:00:00.011423
Build FAILED
Is the cause of “4.11.not_released” same as?
What is the cause of “no build set file found” and “Build FAILED”?
URL: <http://lists.rtems.org/pipermail/users/attachments/20171218/f70c9299/attachment.html>
