RTEMS 4.11.2 building troubles on Windows10
Tue Dec 19 04:13:51 UTC 2017
On 18/12/2017 19:46, 茂呂 智志 wrote:
> I have 2 troubles.
>  1. Then, I have done following command,
> ./rtems-source-builder/sb-check --jobs=none
> Result,
> RTEMS Source Builder -Set Builder, 4.11.not_released
> Environment is ok
> What dose “4.11.not_released” mean and is the cause of “4.11.not_released”?
It is a bug that has been fixed. It will fixed in 4.11.3 when that is released.
>  2. Likewise, I have done following command,
Same issue.
