RTEMS 4.11.2 building troubles on Windows10
Tue Dec 19 04:15:26 UTC 2017
On 19/12/2017 13:13, 茂呂 智志 wrote:
> Thank you for your reply, but I couldn’t build these.
What does the command `pwd` print?
> Is there any need to change the setting of MSYS2? For example, PATH.
No there should not be a need to update PATH.
Please make sure you change into the 'rtems' directory.
