configure problem
bin.wang at qkmtech.com
Tue Dec 26 11:49:35 UTC 2017
i has find this problem is caused by "rtems tools path is not correct"
but when i set the path ok ,there is another problem
console output as follows:
Generating Makefile in build directory: E:/workdir/pallas_SDKworkspace/rtems_kernel_build/build
sh -c "/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure --target=arm-rtems4.11 --prefix=/kernelinstall --enable-rtemsbsp=xilinx_zynq_zc702 --enable-tests --enable-posix --disable-networking --enable-cxx --enable-rtems-debug"
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.11.2
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking target system type... arm-unknown-rtems4.11
checking for a BSD-compatible install... /g/software/xilinx/SDK/2017.3/gnuwin/bin/ginstall -c
configure: error: ls -t appears to fail. Make sure there is not a broken
alias in your environment
configure: error: newly created file is older than distributed files!
Check your system clock
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `IFS
': not a valid identifier
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_precious_vars
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_save_IFS
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_subst_vars
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_user_opts
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `am_lf
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_bourne_compatible
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_nl
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_required
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `exitcode
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_save_IFS
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_status
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_suggested
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_test_x
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_tr_cpp
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_tr_sh
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_unset
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_var
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `bindir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build_cpu
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build_os
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build_vendor
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `cache_file
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `cross_compiling
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `datadir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `datarootdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `docdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `dots
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `dvidir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_cxx
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_networking
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_option_checking
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_posix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_rtems_debug
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_rtemsbsp
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_tests
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `exec_prefix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `exit_status
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host_cpu
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host_os
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host_vendor
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `htmldir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `includedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `infodir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `libdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `libexecdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `localedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `localstatedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `mandir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `no_create
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `no_recursion
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `oldincludedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `pdfdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `pkgdatadir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `prefix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `program_prefix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `program_suffix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `program_transform_name
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `psdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `sbindir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `sharedstatedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `silent
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `site
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `srcdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `subdirs
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `sysconfdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_alias
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_cpu
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_os
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_vendor
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `verbose
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `windows_tracing_flags
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `windows_tracing_logfile
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `x_includes
sed.exe: -e expression #1, char 2: extra characters after command
G:\software\xilinx\SDK\2017.3\gnuwin\bin\rm.exe: cannot remove `*.core': Invalid argument
G:\software\xilinx\SDK\2017.3\gnuwin\bin\rm.exe: cannot remove `core.conftest.*': Invalid argument
checking whether build environment is sane...
Configuration failed with error
Date: 2017-12-26 09:57
To: bin.wang at qkmtech.com; Users
Subject: Re: configure problem
Hi,
Please use the users at rtems.org for User related questions.
On 25/12/17 9:46 pm, bin.wang at qkmtech.com wrote:
> i use the msys2 in the windows7 ,i have install the rtems tools and xilinx
> zynq_zc702 bsp, and i follow the RTEMS Eclipse Manual /Release 4.11.2 pdf ,but
> when i reconfigure the project ,i get the following error ./
> Error 127 occurred while running E:/studydir/rtems/rtems-4.11.2/configurertems-4.11.2-1Configure Problem
There seems to be some missing '/' characters. It is not clear why this is
happening.
URL: <http://lists.rtems.org/pipermail/users/attachments/20171226/01a6a293/attachment-0001.html>
