configure problem
bin.wang at qkmtech.com
Wed Dec 27 04:16:19 UTC 2017
ok ,sorry , i am new to rtems .
yes, i use the MSYS2 to build the tools. so i use the tools path in the xilinx sdk , as the document said ,i add the tools path to the PAHT envirment variable
you means i should use the pure eclipse ? and do not use the xilinx sdk?
now i get the follow error
Generating Makefile in build directory: E:/workdir/pallas_SDKworkspace/rtems_kernel_build/build
sh -c "/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure --target=arm-rtems4.11 --prefix=/kernelinstall --enable-rtemsbsp=xilinx_zynq_zc702 --enable-tests --enable-posix --disable-networking --enable-cxx --enable-rtems-debug"
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.11.2
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking target system type... arm-unknown-rtems4.11
checking for a BSD-compatible install... /g/software/xilinx/SDK/2017.3/gnuwin/bin/ginstall -c
configure: error: ls -t appears to fail. Make sure there is not a broken
alias in your environment
configure: error: newly created file is older than distributed files!
Check your system clock
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `IFS
': not a valid identifier
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_precious_vars
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_save_IFS
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_subst_vars
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `ac_user_opts
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `am_lf
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_bourne_compatible
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_nl
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_required
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `exitcode
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_save_IFS
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_status
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_suggested
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_test_x
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_tr_cpp
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_tr_sh
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_unset
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `as_var
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `bindir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build_cpu
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build_os
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `build_vendor
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `cache_file
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `cross_compiling
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `datadir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `datarootdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `docdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `dots
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `dvidir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_cxx
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_networking
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_option_checking
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_posix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_rtems_debug
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_rtemsbsp
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `enable_tests
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `exec_prefix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `exit_status
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host_cpu
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host_os
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `host_vendor
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `htmldir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `includedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `infodir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `libdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `libexecdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `localedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `localstatedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `mandir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `no_create
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `no_recursion
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `oldincludedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `pdfdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `pkgdatadir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `prefix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `program_prefix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `program_suffix
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `program_transform_name
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `psdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `sbindir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `sharedstatedir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `silent
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `site
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `srcdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `subdirs
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `sysconfdir
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_alias
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_cpu
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_os
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `target_vendor
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `verbose
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `windows_tracing_flags
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `windows_tracing_logfile
/E/workdir/pallas_SDKworkspace/rtems_kernel_build/rtems-4.11.2/configure: line 23: unset: `x_includes
sed.exe: -e expression #1, char 2: extra characters after command
G:\software\xilinx\SDK\2017.3\gnuwin\bin\rm.exe: cannot remove `*.core': Invalid argument
G:\software\xilinx\SDK\2017.3\gnuwin\bin\rm.exe: cannot remove `core.conftest.*': Invalid argument
checking whether build environment is sane...
Configuration failed with error
Date: 2017-12-27 05:55
To: bin.wang at qkmtech.com; Users
Subject: Re: configure problem
Again, please do not post user questions to builds at rtems.org, it is for build
results and not user questions. Thanks.
On 26/12/17 10:49 pm, bin.wang at qkmtech.com wrote:
> i has find this problem is caused by "rtems tools path is not correct"
> but when i set the path ok ,there is another problem
Please remove any reference to any Xilinx SDK tools from your path while you are
building the tools. You need to use MSYS2 to build the tools.
The Xilinx SDK contains it's own environment and this will not be able to build
a set of GCC tools.
URL: <http://lists.rtems.org/pipermail/users/attachments/20171227/6f7dabea/attachment-0001.html>
