make lto-compress.o error & build recovery question
Mon Feb 6 05:16:52 UTC 2017
On 06/02/2017 15:54, Karim, Hassan wrote:
> confirmed! It is very slow. The only exception is where we can use make
> -j ... enabling multi threads/CPU's to get in on the action.
I think more than 1 job with make now works on a recent MSYS2. To be
honest I cannot remember if it is working. For a long time MSYS
(MinGW32) had problems.
> but besides that... I just encountered a bug with the Ubuntu on WSL...
> symlinks to directories don't work as expected. The link apparently gets
> created. One can CD into it. but what's inside of that linked directory
> is ... ghostly. They act like recursive links to the same directory.
Ouch.
> Are symlinks used in the RTEMS set builders?
Yes but indirectly. For example
https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gcc-common-1.cfg#n76.
You could add __ln_s to windows.py as 'cp' to see if it works. I seem to
remember from the distance past that MSYS basically did a copy rather
than create an unsupported link.
Also the RSB cannot control the contents of a tar file is expands and a
tar file can contain a symlink. The same goes for a build system
contained in a package.
