error: no build set file found: arm/realview_pbx_a9_qemu.bset
Mon Feb 6 23:37:41 UTC 2017
Try
../source-builder/sb-set-builder --list-bsets
to get a list of the valid bsets you may use.
On Sun, Feb 5, 2017 at 9:08 PM, Karim, Hassan
<hassan.karim at bison.howard.edu> wrote:
> I've been running in circles dor days trying to compile RTEMS for the
> arm/realview_pbx_a9_qemu BSP.
> what am I doing wrong?
> When I run the setbuilder it says I don't have a bset for realview. I say to
> myself, I know. I was this set builder would create it. But alas... it
> doesn't. Am I missing a step?
> I already built a qemu.bset and I've even gotten to the point where I built
> the erc32 BSP and ran the ticker for sparc/erc32. So I thought I was ready
> to compile.
> ../source-builder/sb-set-builder --without-rtems --log=arm_realvoewbx.log
> --prefix=$HOME/rtems/4.12 arm/realview_pbx_a9_qemu
> RTEMS Source Builder - Set Builder, 4.12 (08f709966f97 modified)
> Build Set: arm/realview_pbx_a9_qemu
> Build Set: Time 0:00:00.002498
> Build FAILED
> Regards,
> Hassan Karim, CISSP
> https://www.linkedin.com/in/hassankarimcissp
> Comp Sci Ph.D. Student
> Howard University
> (202) 569-1012
> users mailing list
> users at rtems.org
