CPU Architecture Target and BSP Listings
DiGiorgio, Joseph
jdigiorg at ball.com
Fri Feb 10 16:04:32 UTC 2017
I am trying to find either in the source or through some command line flag a way to see what targets and BSPs are available when configuring RTEMS.
This documentation, "https://docs.rtems.org/doc-current/share/rtems/html/started/Using-the-RTEMS-configure-Script-Directly.html", says I can find that information in "<RTEMS_Project_Dir>/tools/RTEMS-X.X.X/README.configure, but that file does not exist from what I can see. (I have pulled down the latest copy from the GIT repo for what it's worth)
I also tried looking at the FTP site, "https://docs.rtems.org/doc-current/share/rtems/html/started/Obtain-the-RTEMS-Source-Code.html#Obtain-the-RTEMS-Source-Code", but they only go up to v4.9.
Is there anywhere in the source code itself that I can find supported target and bsp selections I can use when configuring?
- Joey D.
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
