CPU Architecture Target and BSP Listings
Fri Feb 10 19:31:27 UTC 2017
On Fri, Feb 10, 2017 at 11:04 AM, DiGiorgio, Joseph <jdigiorg at ball.com> wrote:
> I am trying to find either in the source or through some command line flag a way to see what targets and BSPs are available when configuring RTEMS.
> This documentation, "https://docs.rtems.org/doc-current/share/rtems/html/started/Using-the-RTEMS-configure-Script-Directly.html",  says I can find that information in "<RTEMS_Project_Dir>/tools/RTEMS-X.X.X/README.configure, but that file does not exist from what I can see. (I have pulled down the latest copy from the GIT repo for what it's worth)
> I also tried looking at the FTP site, "https://docs.rtems.org/doc-current/share/rtems/html/started/Obtain-the-RTEMS-Source-Code.html#Obtain-the-RTEMS-Source-Code", but they only go up to v4.9.
> Is there anywhere in the source code itself that I can find supported target and bsp selections I can use when configuring?
> - Joey D.
> This message and any enclosures are intended only for the addressee.  Please
> notify the sender by email if you are not the intended recipient.  If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful.  Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
Please avoid/disable sending this boilerplate.
https://devel.rtems.org/wiki/TBR/Website/RTEMSMailingLists#Policies
> users mailing list
> users at rtems.org
