build arm-rtems4.12 for big endian
Asif Ahmed
asifahmed.iut at gmail.com
Sun Feb 12 12:59:35 UTC 2017
Hello everyone.
I am totally new with rtems. I have followed the documents and instructions
found online. I have used git clone command to get rtems source builder and
built rsb using command "../source-builder/sb-set-builder \
--prefix=/home/joker/develop/rtems/4.12 4.12/rtems-arm" After that I
have got the rtems source code from git and installed it in a non-root
directory with option --enable-rtems=tms570ls3137_hdk_intram and exported
the path. But in eclipse i get the error that " ./Init.o: compiled for a
big endian system and target is little endian ". I have seen in make/custom
folder of TMS570 that CPU_FLAGS = -mbig-endian but in arm.h and cpu.h and
mchine/endian.h all files indicates that __ARMEL__ is defiend and target is
little endian.
I need your help guys to get started with rtems. I may have missed some
thing. I appreciate any kind of suggestion.
Best Regards
Asif Ahmed
URL: <http://lists.rtems.org/pipermail/users/attachments/20170212/fac1694e/attachment.html>
