CPU Architecture Target and BSP Listings
    DiGiorgio, Joseph
    jdigiorg at ball.com
    Fri Feb 10 16:45:39 UTC 2017
I tried that and it seems like it has a problem with the find command. It doesn't look like it needs any arguments, so I have to open it up and see what's wrong.
-----Original Message-----
From: Jan.Sommer at dlr.de [mailto:Jan.Sommer at dlr.de]
Sent: Friday, February 10, 2017 11:14 AM
To: DiGiorgio, Joseph; users at rtems.org
Subject: AW: CPU Architecture Target and BSP Listings
> -----Ursprüngliche Nachricht-----
> Von: users [mailto:users-bounces at rtems.org] Im Auftrag von DiGiorgio, Joseph
> Gesendet: Freitag, 10. Februar 2017 17:05
> An: users at rtems.org
> Betreff: CPU Architecture Target and BSP Listings
> I am trying to find either in the source or through some command line flag a way
> to see what targets and BSPs are available when configuring RTEMS.
In the rtems project directory there is the script rtems-bsps which
will print a list of all available bsps and their architecture.
Is this what you are looking for?
Best regards
   Jan
> This documentation, "https://urldefense.proofpoint.com/v2/url?u=https-3A__docs.rtems.org_doc-2D&d=DwIFAw&c=jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=0m-2IWA4nG8XXUsoxxX10xjdgHGHm22AGbkiiX_IAEI&s=xQylSmIkYHcE-tlt3Ab3Us0XjWo0II902SJJQ9sU9j0&e=
> current/share/rtems/html/started/Using-the-RTEMS-configure-Script-
> Directly.html",  says I can find that information in
> "<RTEMS_Project_Dir>/tools/RTEMS-X.X.X/README.configure, but that file
> does not exist from what I can see. (I have pulled down the latest copy from the
> GIT repo for what it's worth)
> I also tried looking at the FTP site, "https://urldefense.proofpoint.com/v2/url?u=https-3A__docs.rtems.org_doc-2D&d=DwIFAw&c=jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=0m-2IWA4nG8XXUsoxxX10xjdgHGHm22AGbkiiX_IAEI&s=xQylSmIkYHcE-tlt3Ab3Us0XjWo0II902SJJQ9sU9j0&e=
> current/share/rtems/html/started/Obtain-the-RTEMS-Source-
> Code.html#Obtain-the-RTEMS-Source-Code", but they only go up to v4.9.
> Is there anywhere in the source code itself that I can find supported target and
> bsp selections I can use when configuring?
> - Joey D.
> This message and any enclosures are intended only for the addressee.  Please
> notify the sender by email if you are not the intended recipient.  If you are not
> the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful.  Ball reserves the right to monitor and review all messages and
> enclosures sent to or from this email address.
> users mailing list
> users at rtems.org
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwIFAw&c=jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=0m-2IWA4nG8XXUsoxxX10xjdgHGHm22AGbkiiX_IAEI&s=8ELOadd97ZAQg6e5SUJ_Fq-jhKdHOXogBQykAnoVlYU&e=
not the intended recipient, you may not use, copy, disclose, or distribute this
and enclosures sent to or from this email address.
