CPU Architecture Target and BSP Listings
    Joel Sherrill
    joel at rtems.org
    Fri Feb 10 16:54:44 UTC 2017
Grrr.. that find command won't stay fixed. :(
Is this on the master or 4.11?
On Feb 10, 2017 11:50 AM, "DiGiorgio, Joseph" <jdigiorg at ball.com> wrote:
> Seems like the -depth 5 is causing the problem. Should this have been
> -maxdepth 5?
> -----Original Message-----
> From: Jan.Sommer at dlr.de [mailto:Jan.Sommer at dlr.de]
> Sent: Friday, February 10, 2017 11:14 AM
> To: DiGiorgio, Joseph; users at rtems.org
> Subject: AW: CPU Architecture Target and BSP Listings
> > -----Ursprüngliche Nachricht-----
> > Von: users [mailto:users-bounces at rtems.org] Im Auftrag von DiGiorgio,
> Joseph
> > Gesendet: Freitag, 10. Februar 2017 17:05
> > An: users at rtems.org
> > Betreff: CPU Architecture Target and BSP Listings
> > I am trying to find either in the source or through some command line
> flag a way
> > to see what targets and BSPs are available when configuring RTEMS.
> In the rtems project directory there is the script rtems-bsps which
> will print a list of all available bsps and their architecture.
> Is this what you are looking for?
> Best regards
>    Jan
> > This documentation, "https://urldefense.proofpoint.com/v2/url?u=https-
> 3A__docs.rtems.org_doc-2D&d=DwIFAw&c=jF7FvYH6t0RX1HrEjVCgHQ&r=
> bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=0m-
> 2IWA4nG8XXUsoxxX10xjdgHGHm22AGbkiiX_IAEI&s=xQylSmIkYHcE-
> tlt3Ab3Us0XjWo0II902SJJQ9sU9j0&e=
> > current/share/rtems/html/started/Using-the-RTEMS-configure-Script-
> > Directly.html",  says I can find that information in
> > "<RTEMS_Project_Dir>/tools/RTEMS-X.X.X/README.configure, but that file
> > does not exist from what I can see. (I have pulled down the latest copy
> from the
> > GIT repo for what it's worth)
> > I also tried looking at the FTP site, "https://urldefense.
> proofpoint.com/v2/url?u=https-3A__docs.rtems.org_doc-2D&d=DwIFAw&c=
> jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=0m-
> > current/share/rtems/html/started/Obtain-the-RTEMS-Source-
> > Code.html#Obtain-the-RTEMS-Source-Code", but they only go up to v4.9.
> > Is there anywhere in the source code itself that I can find supported
> target and
> > bsp selections I can use when configuring?
> > - Joey D.
> > This message and any enclosures are intended only for the addressee.
> Please
> > notify the sender by email if you are not the intended recipient.  If
> you are not
> > the intended recipient, you may not use, copy, disclose, or distribute
> this
> > message or its contents or enclosures to any other person and any such
> actions
> > may be unlawful.  Ball reserves the right to monitor and review all
> messages and
> > enclosures sent to or from this email address.
> > users mailing list
> > users at rtems.org
> > https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.
> rtems.org_mailman_listinfo_users&d=DwIFAw&c=jF7FvYH6t0RX1HrEjVCgHQ&r=
> 2IWA4nG8XXUsoxxX10xjdgHGHm22AGbkiiX_IAEI&s=8ELOadd97ZAQg6e5SUJ_Fq-
> jhKdHOXogBQykAnoVlYU&e=
> Please
> notify the sender by email if you are not the intended recipient.  If you
> are
> not the intended recipient, you may not use, copy, disclose, or distribute
> this
> actions
> messages
> and enclosures sent to or from this email address.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170210/afd6e1e9/attachment-0002.html>
