RTEMS Source Builder URLOpen Error 104
Joey DiGiorgio digiorgiojoey at gmail.com
Wed Feb 22 02:43:08 UTC 2017
I never got it resolved. I asked my network admins and they gave me white
list access and it still didn't work. I ended up having to modify a script
in the source builder to use wget with http protocol. I can send you the
patch file I'm temporarily using tomorrow when I'm back at my machine.
- Joey D.
On Feb 21, 2017 7:05 PM, "Chris Johns" <chrisj at rtems.org> wrote:
On 15/02/2017 02:33, Joey DiGiorgio wrote:
> I cloned a fresh copy of the RTEMS Source Builder, switched to the
> 4.11.0 tag, and tried to follow the directions listed at
> https://docs.rtems.org/rsb/
> Below is the output I get in the terminal as well as the generated log
> file.
> The weird thing is, I have done this same process within the past 3 or
> so weeks and it worked without any issues.
> Terminal Output:
> ../source-builder/sb-set-builder
> --prefix=/home/xubuntu/Development/RTEMS/RTEMS_Cross_Tools
> --log=l-log.log 4.11/rtems-powerpc
> RTEMS Source Builder - Set Builder, 4.11 (1675a733536d modified)
> Build Set: 4.11/rtems-powerpc
> Build Set: 4.11/rtems-autotools.bset
> Build Set: 4.11/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> package: autoconf-2.69-x86_64-linux-gnu-1
> download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz ->
> sources/autoconf-2.69.tar.gz
> download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: error:
> <urlopen error ftp error: [Errno 104] Connection reset by peer>
> error: downloading
> ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz: all paths have
> failed, giving up
> Build FAILED
>   See error report: rsb-report-autoconf-2.69-x86_64-linux-gnu-1.txt
> error: downloading
> failed, giving up
> Build Set: Time 0:00:00.903983
> error: downloading
> failed, giving up
> Build Set: Time 0:00:00.905238
> error: downloading
> failed, giving up
> Build Set: Time 0:00:00.908253
> Build FAILED
Has this been resolved and can you now download from ftp.gnu.org?
I wonder if they are blocking us now.
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20170221/20149c8a/attachment-0002.html>
