rtems-tools building error
Joel Sherrill
joel at rtems.org
Sat Jan 7 23:27:38 UTC 2017
On Sat, Jan 7, 2017 at 3:59 PM, Denis Obrezkov <denisobrezkov at gmail.com>
wrote:
> Hello,
> I cloned rtems-tools from https://git.rtems.org/rtems-tools
> and I can't build them:
> ~/Projects/rtems/rtems-tools$ ./waf configure
> --prefix=$HOME/Projects/rtems/4.11
> Setting top to : /home/reprofy/Projects/rtems/
> rtems-tools
> Setting out to : /home/reprofy/Projects/rtems/
> rtems-tools/build
> Version : 4.12.516f9311e61f (4.12)
> Checking for program 'python' : /usr/bin/python
> Checking for python version : (2, 7, 9, 'final', 0)
> Checking for 'gcc' (C compiler) : /usr/bin/gcc
> Checking for 'g++' (C++ compiler) : /usr/bin/g++
> Checking for header alloca.h : yes
> Checking for header fcntl.h : yes
> Checking for header process.h : not found
> Checking for header stdlib.h : yes
> Checking for header string.h : yes
> Checking for header strings.h : yes
> Checking for header sys/file.h : yes
> Checking for header sys/stat.h : yes
> Checking for header sys/time.h : yes
> Checking for header sys/types.h : yes
> Checking for header sys/wait.h : yes
> Checking for header unistd.h : yes
> Checking for header vfork.h : not found
> Checking for function getrusage : yes
> Checking for program 'm4' : /usr/bin/m4
> Checking for function kill : yes
> Checking for function open64 : not found
> Checking for function stat64 : not found
> 'configure' finished successfully (0.585s)
> reprofy at repdell:~/Projects/rtems/rtems-tools$ ./waf build install
> Waf: Entering directory `/home/reprofy/Projects/rtems/rtems-tools/build'
> [ 5/145] Compiling rtemstoolkit/elftoolchain/libelf/elf.c
> [ 12/145] Compiling rtemstoolkit/elftoolchain/libelf/elf_fill.c
> [ 13/145] Compiling rtemstoolkit/elftoolchain/libelf/elf_flag.c
> [ 14/145] Compiling rtemstoolkit/elftoolchain/libelf/elf_getarhdr.c
> ../rtemstoolkit/elftoolchain/libelf/elf.c:34:29: error: expected
> expression before ‘,’ token
> .libelf_arch = LIBELF_ARCH,
:LIBELF_ARCH is defined based on the architecture libelf is being compiled
for. The file elf.c is pretty simple and LIBELF is conditionally defined in
this file:
https://git.rtems.org/rtems-tools/plain/rtemstoolkit/elftoolchain/libelf/_libelf_config.h
Since the definition of LIBARCH_ARCH is dependent on the host architecture,
what host are you compiling on?
Also the following command will show you all the gcc predefines. Is one of
them
for the architecture in the libelf_config.h file?
gcc -dM -E - </dev/null | less
> Waf: Leaving directory `/home/reprofy/Projects/rtems/rtems-tools/build'
> Build failed
> -> task in 'elf' failed (exit status 1):
> {task 140143375691152: c elf.c -> elf.c.5.o}
> ['/usr/bin/gcc', '-pipe', '-g', '-O2', '-I/home/reprofy/Projects/rtems/rtems-tools/build',
> '-I/home/reprofy/Projects/rtems/rtems-tools/build/
> rtemstoolkit/elftoolchain/libelf', '-I/home/reprofy/Projects/
> rtems/rtems-tools/rtemstoolkit/elftoolchain/libelf',
> rtemstoolkit/elftoolchain/common', '-I/home/reprofy/Projects/
> rtems/rtems-tools/rtemstoolkit/elftoolchain/common',
> '../rtemstoolkit/elftoolchain/libelf/elf.c', '-c', '-o',
> '/home/reprofy/Projects/rtems/rtems-tools/build/rtemstoolkit/elftoolchain/
> libelf/elf.c.5.o']
> Regards, Denis Obrezkov
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170107/70a29f50/attachment.html>
