RTEMS Quick Start Instructions Not Working
DiGiorgio, Joseph
jdigiorg at ball.com
Thu Jan 19 16:24:51 UTC 2017
I feel silly. You are right. There is a note I missed stating to use the erc32. One other place I looked up BSPs when initially setting things up was https://devel.rtems.org/wiki/TBR/Website/Board_Support_Packages#SPARCBSPs. I didn’t see any notes about sis being removed and to use the erc32 instead.
Made the change and it complies now.
Thanks Joel!
- Joey D.
Sent: Thursday, January 19, 2017 11:13 AM
To: DiGiorgio, Joseph
Cc: users at rtems.org
Subject: Re: RTEMS Quick Start Instructions Not Working
Minor issue where you missed the note that the sis BSP is not needed
any longer and was recently removed. The simulator in gdb now initializes
in the same state as the real HW erc32.
Replace sis with erc32 and you should be OK.
Double check me on the page. I think I added a note about this. It may need
to be repeated in more spots.
--joel
On Thu, Jan 19, 2017 at 10:09 AM, DiGiorgio, Joseph <jdigiorg at ball.com<mailto:jdigiorg at ball.com>> wrote:
Hi,
I have tried several different configurations in following the Quick Start instructions (https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start<https://urldefense.proofpoint.com/v2/url?u=https-3A__devel.rtems.org_wiki_TBR_UserManual_Quick-5FStart&d=DwMFaQ&c=jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=OF6z52Pk9cEnscrNMZC-2rRhjLM2CYargXBKy7O0rJk&s=N5nE7TKs2ctAT3XrchRQm1U2FsPZGnIXB4tz5_I-N0A&e=>) and have not had any success getting a successful RTEMS environment up and running. My ultimate goal is to get a powerpc RTEMS running under QEMU, but I have simplified my attempt to purely following the Quick Start guide with SPARC as the target which I can’t seem to get that to work.
I have successfully used the “RTEMS Source Builder” to create my cross compiler suite for SPARC architecture (https://docs.rtems.org/rsb/<https://urldefense.proofpoint.com/v2/url?u=https-3A__docs.rtems.org_rsb_&d=DwMFaQ&c=jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=OF6z52Pk9cEnscrNMZC-2rRhjLM2CYargXBKy7O0rJk&s=2FlykUuqxhXwfK_pKtQK6DD0PRbwQFpfvcxIXmt18Kg&e=>).
I have setup the following directory structure
RTEMS
+---RTEMS_Cross_Tools
| +---dist
| +---SPARC
| +---bin
| +---include
| +---lib
| +---libexec
| +---share
| +---sparc-rtems4.12
+---RTEMS_OS
| +---build
| +---dist
| +---Source
and used Git to obtain a recent version of RTEMS:
cd RTEMS_OS
git clone git://git.rtems.org/rtems.git<https://urldefense.proofpoint.com/v2/url?u=http-3A__git.rtems.org_rtems.git&d=DwMFaQ&c=jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=OF6z52Pk9cEnscrNMZC-2rRhjLM2CYargXBKy7O0rJk&s=h-1gHcqPnMH1SH9E1R82TSb98VeUV-w6BUycvT0hALA&e=> ./Source
I am using the following script to build RTEMS:
export RTEMS_CROSS_TOOLS_PREFIX=/home/xubuntu/Development/RTEMS/RTEMS_Cross_Tools/dist/SPARC
export RTEMS_INSTALL_PREFIX=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC
export RTEMS_TARGET_ARCH=sparc-rtems4.12
export RTEMS_BOARD_SUPPORT_PACKAGE=sis
PROJECT_DIR=${PWD}
export PATH=${RTEMS_CROSS_TOOLS_PREFIX}/bin:${PATH}
if [! -f ../Source/configure]; then
pushd Source
echo "Running bootstrap to generate configure files..."
echo
./bootstrap 2>&1 | tee ${PROJECT_DIR}/bootstrap.log
echo "Bootstrap operation complete..."
echo
popd
read -n 1 -p "Any key to continue, ^c to Terminate..." userinput
fi
pushd build
echo "Configuring RTEMS OS..."
echo
../Source/configure \
--target=${RTEMS_TARGET_ARCH} \
--enable-rtemsbsp=${RTEMS_BOARD_SUPPORT_PACKAGE} \
--prefix=${RTEMS_INSTALL_PREFIX} \
--enable-tests=samples \
2>&1 | tee ${PROJECT_DIR}/configure.log
echo "Configure operation complete."
echo
popd
pushd build
echo "Building RTEMS OS..."
echo
make 2>&1 | tee ${PROJECT_DIR}/build.log
echo "Build operation complete."
echo
popd
pushd build
echo "Installing RTEMS OS..."
echo
make install 2>&1 | tee ${PROJECT_DIR}/install.log
echo "Install operation complete."
echo
popd
The following is my output for configure and make:
configure.log
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.11.99.0
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... sparc-unknown-rtems4.12
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking that generated files are newer than configure... done
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/bash '../../../Source/tools/build/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12' '--cache-file=/dev/null' '--srcdir=../../../Source/tools/build'
checking for x86_64-pc-linux-gnu-gcc... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking libgen.h usability... yes
checking libgen.h presence... yes
checking for libgen.h... yes
checking for strerror... yes
checking for strtol... yes
checking for basename... yes
checking for strnlen... yes
checking for bash... /bin/bash
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
configure: running /bin/bash '../../../Source/tools/cpu/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12' '--cache-file=/dev/null' '--srcdir=../../../Source/tools/cpu'
checking rtems target cpu... sparc
=== configuring in generic (/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic)
configure: running /bin/bash ../../../../Source/tools/cpu/generic/configure --disable-option-checking '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12' 'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu' 'target_alias=sparc-rtems4.12' --cache-file=/dev/null --srcdir=../../../../Source/tools/cpu/generic
config.status: creating size_rtems
configure: configuring in ./testsuites/tools
configure: running /bin/bash '../../../Source/testsuites/tools/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12' '--cache-file=/dev/null' '--srcdir=../../../Source/testsuites/tools'
=== configuring in generic (/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic)
configure: running /bin/bash ../../../../Source/testsuites/tools/generic/configure --disable-option-checking '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12' 'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu' 'target_alias=sparc-rtems4.12' --cache-file=/dev/null --srcdir=../../../../Source/testsuites/tools/generic
config.status: creating difftest
config.status: creating sorttimes
configure: configuring in sparc-rtems4.12/c
configure: running /bin/bash '../../../Source/c/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=sparc-rtems4.12' '--build=x86_64-pc-linux-gnu' '--target=sparc-rtems4.12' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--with-target-subdir=sparc-rtems4.12' '--exec-prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC/sparc-rtems4.12' '--includedir=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC/sparc-rtems4.12/include' '--cache-file=/dev/null' '--srcdir=../../../Source/c'
checking host system type... sparc-unknown-rtems4.12
checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
build.log
Making all in tools/build
make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
make all-am
make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
Making all in tools/cpu
make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
Making all in generic
make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic'
make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
make[2]: Nothing to be done for 'all-am'.
make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
Making all in testsuites/tools
make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic'
make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic'
make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
Making all in sparc-rtems4.12/c
make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
Making all in .
make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build'
make[1]: Nothing to be done for 'all-am'.
make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build'
When I inspect my build directory, I see make files, but nothing seems to be compiled. I also search for the “samples” test program “ticker” and do not see anything in my project directory. Any ideas what I’m doing wrong?
- Joey D.
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users<https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=jF7FvYH6t0RX1HrEjVCgHQ&r=bcW4I2OeTMRR6lOqlbMy8LAX0B8qqHDKCKLLVCaH1TA&m=OF6z52Pk9cEnscrNMZC-2rRhjLM2CYargXBKy7O0rJk&s=gT5h2r9fYH5JvvfqLA5ZJVp6rBKcV5__irmcSAg92QU&e=>
URL: <http://lists.rtems.org/pipermail/users/attachments/20170119/e0afa752/attachment-0001.html>
