RTEMS Quick Start Instructions Not Working
Thu Jan 19 17:19:16 UTC 2017
Thanks I added a note on the referenced wiki page, and the SIS page directly.
On Thu, Jan 19, 2017 at 11:24 AM, DiGiorgio, Joseph <jdigiorg at ball.com> wrote:
> I feel silly. You are right. There is a note I missed stating to use the
> erc32. One other place I looked up BSPs when initially setting things up was
> https://devel.rtems.org/wiki/TBR/Website/Board_Support_Packages#SPARCBSPs. I
> didn’t see any notes about sis being removed and to use the erc32 instead.
> Made the change and it complies now.
> Thanks Joel!
> - Joey D.
> From: Joel Sherrill [mailto:joel at rtems.org]
> Sent: Thursday, January 19, 2017 11:13 AM
> To: DiGiorgio, Joseph
> Cc: users at rtems.org
> Subject: Re: RTEMS Quick Start Instructions Not Working
> Minor issue where you missed the note that the sis BSP is not needed
> any longer and was recently removed. The simulator in gdb now initializes
> in the same state as the real HW erc32.
> Replace sis with erc32 and you should be OK.
> Double check me on the page. I think I added a note about this. It may need
> to be repeated in more spots.
> --joel
> On Thu, Jan 19, 2017 at 10:09 AM, DiGiorgio, Joseph <jdigiorg at ball.com>
> wrote:
> Hi,
> I have tried several different configurations in following the Quick Start
> instructions (https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start) and
> have not had any success getting a successful RTEMS environment up and
> running. My ultimate goal is to get a powerpc RTEMS running under QEMU, but
> I have simplified my attempt to purely following the Quick Start guide with
> SPARC as the target which I can’t seem to get that to work.
> I have successfully used the “RTEMS Source Builder” to create my cross
> compiler suite for SPARC architecture (https://docs.rtems.org/rsb/).
> I have setup the following directory structure
> RTEMS
> +---RTEMS_Cross_Tools
> |   +---dist
> |       +---SPARC
> |           +---bin
> |           +---include
> |           +---lib
> |           +---libexec
> |           +---share
> |           +---sparc-rtems4.12
> +---RTEMS_OS
> |   +---build
> |   +---dist
> |   +---Source
> and used Git to obtain a recent version of RTEMS:
>     cd RTEMS_OS
>     git clone git://git.rtems.org/rtems.git ./Source
> I am using the following script to build RTEMS:
>     export
> RTEMS_CROSS_TOOLS_PREFIX=/home/xubuntu/Development/RTEMS/RTEMS_Cross_Tools/dist/SPARC
>     export
> RTEMS_INSTALL_PREFIX=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC
>     export RTEMS_TARGET_ARCH=sparc-rtems4.12
>     export RTEMS_BOARD_SUPPORT_PACKAGE=sis
>     PROJECT_DIR=${PWD}
>     export PATH=${RTEMS_CROSS_TOOLS_PREFIX}/bin:${PATH}
>     if [! -f ../Source/configure]; then
>     pushd Source
>         echo "Running bootstrap to generate configure files..."
>         echo
>         ./bootstrap 2>&1 | tee ${PROJECT_DIR}/bootstrap.log
>         echo "Bootstrap operation complete..."
>         echo
>     popd
>     read -n 1 -p "Any key to continue, ^c to Terminate..." userinput
>     fi
>     pushd build
>         echo "Configuring RTEMS OS..."
>         echo
>         ../Source/configure \
>             --target=${RTEMS_TARGET_ARCH} \
>             --enable-rtemsbsp=${RTEMS_BOARD_SUPPORT_PACKAGE} \
>             --prefix=${RTEMS_INSTALL_PREFIX} \
>             --enable-tests=samples \
>             2>&1 | tee ${PROJECT_DIR}/configure.log
>         echo "Configure operation complete."
>         echo
>     popd
>     pushd build
>         echo "Building RTEMS OS..."
>         echo
>         make 2>&1 | tee ${PROJECT_DIR}/build.log
>         echo "Build operation complete."
>         echo
>     popd
>     pushd build
>         echo "Installing RTEMS OS..."
>         echo
>         make install 2>&1 | tee ${PROJECT_DIR}/install.log
>         echo "Install operation complete."
>         echo
>     popd
> The following is my output for configure and make:
>     configure.log
>     checking for gmake... no
>     checking for make... make
>     checking for RTEMS Version... 4.11.99.0
>     checking build system type... x86_64-pc-linux-gnu
>     checking host system type... x86_64-pc-linux-gnu
>     checking target system type... sparc-unknown-rtems4.12
>     checking for a BSD-compatible install... /usr/bin/install -c
>     checking whether build environment is sane... yes
>     checking for a thread-safe mkdir -p... /bin/mkdir -p
>     checking for gawk... gawk
>     checking whether make sets $(MAKE)... yes
>     checking whether to enable maintainer-specific portions of Makefiles...
> no
>     checking that generated files are newer than configure... done
>     configure: creating ./config.status
>     configure: configuring in ./tools/build
>     configure: running /bin/bash '../../../Source/tools/build/configure'
> '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC'
> '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'
> '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12'
> '--cache-file=/dev/null' '--srcdir=../../../Source/tools/build'
> no
>     checking for x86_64-pc-linux-gnu-gcc... no
>     checking for gcc... gcc
>     checking whether the C compiler works... yes
>     checking for C compiler default output file name... a.out
>     checking for suffix of executables...
>     checking whether we are cross compiling... no
>     checking for suffix of object files... o
>     checking whether we are using the GNU C compiler... yes
>     checking whether gcc accepts -g... yes
>     checking for gcc option to accept ISO C89... none needed
>     checking for style of include used by make... GNU
>     checking dependency style of gcc... gcc3
>     checking how to run the C preprocessor... gcc -E
>     checking for grep that handles long lines and -e... /bin/grep
>     checking for egrep... /bin/grep -E
>     checking for ANSI C header files... yes
>     checking for sys/types.h... yes
>     checking for sys/stat.h... yes
>     checking for stdlib.h... yes
>     checking for string.h... yes
>     checking for memory.h... yes
>     checking for strings.h... yes
>     checking for inttypes.h... yes
>     checking for stdint.h... yes
>     checking for unistd.h... yes
>     checking getopt.h usability... yes
>     checking getopt.h presence... yes
>     checking for getopt.h... yes
>     checking libgen.h usability... yes
>     checking libgen.h presence... yes
>     checking for libgen.h... yes
>     checking for strerror... yes
>     checking for strtol... yes
>     checking for basename... yes
>     checking for strnlen... yes
>     checking for bash... /bin/bash
>     config.status: creating Makefile
>     config.status: creating install-if-change
>     config.status: creating config.h
>     config.status: config.h is unchanged
>     config.status: executing depfiles commands
>     configure: configuring in ./tools/cpu
>     configure: running /bin/bash '../../../Source/tools/cpu/configure'
> '--cache-file=/dev/null' '--srcdir=../../../Source/tools/cpu'
>     checking rtems target cpu... sparc
> no
>     === configuring in generic
> (/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic)
> ../../../../Source/tools/cpu/generic/configure --disable-option-checking
> 'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu'
> 'target_alias=sparc-rtems4.12' --cache-file=/dev/null
> --srcdir=../../../../Source/tools/cpu/generic
> no
>     config.status: creating size_rtems
>     configure: configuring in ./testsuites/tools
> '../../../Source/testsuites/tools/configure'
> '--cache-file=/dev/null' '--srcdir=../../../Source/testsuites/tools'
> no
> (/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic)
> ../../../../Source/testsuites/tools/generic/configure
> --srcdir=../../../../Source/testsuites/tools/generic
> no
>     config.status: creating difftest
>     config.status: creating sorttimes
>     configure: configuring in sparc-rtems4.12/c
>     configure: running /bin/bash '../../../Source/c/configure'
> '--host=sparc-rtems4.12' '--build=x86_64-pc-linux-gnu'
> '--target=sparc-rtems4.12'  '--enable-rtemsbsp=sis' '--enable-tests=samples'
> '--with-target-subdir=sparc-rtems4.12'
> '--exec-prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC/sparc-rtems4.12'
> '--includedir=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC/sparc-rtems4.12/include'
> '--cache-file=/dev/null' '--srcdir=../../../Source/c'
>     checking host system type... sparc-unknown-rtems4.12
>     checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
> no
>     build.log
>     Making all in tools/build
>     make[1]: Entering directory
> '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
>     make  all-am
>     make[2]: Entering directory
>     make[2]: Leaving directory
>     make[1]: Leaving directory
>     Making all in tools/cpu
> '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
>     Making all in generic
> '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic'
>     make[2]: Nothing to be done for 'all'.
>     make[2]: Nothing to be done for 'all-am'.
>     Making all in testsuites/tools
> '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
> '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic'
>     Making all in sparc-rtems4.12/c
> '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
>     Making all in .
> '/home/xubuntu/Development/RTEMS/RTEMS_OS/build'
>     make[1]: Nothing to be done for 'all-am'.
> When I inspect my build directory, I see make files, but nothing seems to be
> compiled. I also search for the “samples” test program “ticker” and do not
> see anything in my project directory. Any ideas what I’m doing wrong?
> - Joey D.
> This message and any enclosures are intended only for the addressee. Please
> notify the sender by email if you are not the intended recipient. If you are
> not the intended recipient, you may not use, copy, disclose, or distribute
> this
> message or its contents or enclosures to any other person and any such
> actions
> may be unlawful. Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> users mailing list
> users at rtems.org
> this
> actions
> users mailing list
> users at rtems.org
